Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
which ECU should I get?
Old May 27, 2002 | 09:29 AM
mrfixxit7's Avatar
I have a 93 fd with the following:
-HKS cat back & HKS ss bov
-Enfini y-pipe
-PFS stock mount IC & PFS Cold air intake
-Greddy elbow & hard pipe kit
What ecu would you guys recommend? I might be leaving FL. soon and heading to CA. so emissions could be a problem. I do plan to do more upgrades, like down pipe, maybe a mid pipe, injectors if needed. So I think I would need something that is tuneable wouldn't I? Also would I need anything other than a ECU with those upgrades to prevent things like boost creep, or boost control? Thanks
Old May 28, 2002 | 09:47 AM
Evil Aviator's Avatar
Rotorhead
It is probably best to get a purchase/installation/tuning package deal at your local rotary-smart performance shop. I don't think that the brand matters all that much, just as long as the shop can produce the results that you want. If you are going to Kalifornia, you may want to have a shop over there do it because they will know what is required to pass emissions.
Boost creep is caused by an inadequate wastegate, so this will only be solved by porting or replacement. Some aftermarket EMS units have boost control, while others do not. I suggest posting in the 3Gen forum to see what brand people like for your car.
Old May 29, 2002 | 12:14 AM
jreynish's Avatar
New Project on the Way...
well i have a 1990 TII with a T04 turbo and i was simply wondering if there is a backpack or what i should do for my too much boost prob!!! And well i think simply that i need some advice what!!! how much and where i can get it and it's advantages or disadvantages would help me alot!!! thanks in advance for the help!
Old May 29, 2002 | 12:37 AM
Nameless's Avatar
Dont concern yourself with the legality of an ECU in CA if u are going to go with a MP anyway. Only way u'll pass is to pay someone off, with either a good standalone or MP (same goes with a DP, it's not legal anyway). Heck I saw someone fail smog for a blow-off valve.
You might want to hold off on modifications until after you've moved to CA. Because when you bring an out of state vehicle I think it needs to be inspected by someone (I forget who).
Old May 30, 2002 | 08:46 AM
mrfixxit7's Avatar
I am in the military so I can keep the FL. plates. So that should help. So what ecu do you guys recommend? And what are the pros and cons of the different ones out there?
Old Jun 1, 2002 | 02:23 AM
mrfixxit7's Avatar
ok, but what ecu do you guys recommend? what are the advantages and disadvantages of the more popular ones out there? Such as the PFS, Power fc, Haltec, AEM?Out here in Pensacola I am limited in the number of Techs. as far as mapping and tunning the car
Old Jun 1, 2002 | 11:37 AM
Rotorhead
What do your Techs know how to work with?
Old Jun 1, 2002 | 03:30 PM
SexyRexyR1's Avatar
I've heard a lot of good things about PFC .... Haltech is outta the question if you want to pass smog. AEM i'm not too sure about, it just seems to have a bunch of features that have no real use. (to me anyways) PFS dunno, doesn't seem too user friendly (unless you have a gauge for everything on your car.
I'm going with a PFC at the end of summer, once my new engine is broken in. I have similar mods ...
If you don't have any ambiion to go single turbo ... you could just get your stock ecu remapped by M2 or pettit. But once it's done ... it's done. You can't tune it afterwards ...
Hope this helps, and i encourage someone with more knowledge to chime in.
Good Luck
Old Jun 1, 2002 | 07:08 PM
mrfixxit7's Avatar
thanks does the PFC have a boost controller?
Erosangel
Sep 18, 2015 10:28 PM
Erosangel
Sep 18, 2015 04:06 PM
