Pull-Up Windows...racestyle!
Old Apr 7, 2009 | 06:50 AM
sarniamike's Avatar
My drivers window is giving me problem and I've read the lowdown on possible problems and am not interested.
What I am interested in is taking out weight and having a hassle free RX experience. So...I would like to gut the doors with the exception of the guide rails, put Lexan windows in and use a strap or maybe Venetian blind cords with the little locks to bring the windows up and down and lock them in place.
Anybody ever do anything remotely similar??
Thanks guys
Mike
Old Apr 7, 2009 | 08:47 AM
Aaron Cake's Avatar
Engine, Not Motor
I assume you are having issues with the window switches?
You can rather easily rewire them with a generic set of DPDT switches.
Or, if you want to simplify, then swap in the manual regulators.
Old Apr 7, 2009 | 01:42 PM
sarniamike's Avatar
How do I know if it's the switches or the motors? I noticed the power coming out of the drivers side of the switch was only 9V. Is there any way to check or is that proof enough?
Mike
Old Apr 7, 2009 | 06:05 PM
Aaron Cake's Avatar
Engine, Not Motor
Testing procedures are in the FSM.
But 9V probably indicates that the switch contacts are burned. Very common issue.
Old Apr 8, 2009 | 01:14 PM
sarniamike's Avatar
What is the FSM? More often then not is it the switches?
Old Apr 8, 2009 | 01:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Factory Service Manual.
The contacts in the switches burn up all the time. Mine are due for another cleaning.
Old Apr 8, 2009 | 03:45 PM
whitealexander's Avatar
i needed this one too thanks..
C. Ludwig
Haltech Forum
May 9, 2012 06:05 AM
FC3Sdrift
Megasquirt Forum
May 13, 2011 09:04 PM
hiroichi1515
Megasquirt Forum
Jun 15, 2010 08:17 PM
kepsus
Wolf 3D
Apr 11, 2009 06:24 AM
