ACS while getting PFC
Old Apr 1, 2009 | 10:18 AM
JDMinard's Avatar
Question ACS while getting PFC
Hi guys
Just buy my first FD (JDM) and the japonnese that had it before puts a cat-back and an air/flow conditonner system.
I'll soon buy a hks racing suction kit and want to know:
Will i run lean?
If yes does the acs is good for low mods instead of a PFC (i'll get one later)
Can i easily tune the acs myself?
I'm now running a 12-9-12 psi pattern, egt between 600-700Celcius on normal driving
Am i already lean? ( ACS indicate "normal")
Thank you
Old Apr 1, 2009 | 11:49 AM
dgeesaman's Avatar
I don't know what you mean by an ACS.
Is the only modification on the car a cat-back? If so, running an intake also is fine as long as the boost stays at 12psi. Do not let it exceed 12psi.
David
Old Apr 1, 2009 | 11:58 AM
JDMinard's Avatar
ACS: air/flow conditinner system, air/fuel ratio
Adding air intake will rise the pressure no?
So if i understand, more than 12psi and i need to tune the air/fuel ratio?
Boost controller can bring it down to 12 but not under 10 is that it? (stock boost)
Einheri
Oct 7, 2015 12:23 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
kryan9
Sep 15, 2015 10:11 PM
