No Power
Old Mar 31, 2009 | 03:06 PM
Bluenutz's Avatar
No Power
as soon as check engine light comes on car looses acceleration. It will only accelerate at barely a push of the pedal, but when floored it wants to stall and hesitate. Could this be the fuel pressure regulator? I don't get a code for the pump and it has a new fuel filter. When idling runs fine.
Old Mar 31, 2009 | 04:27 PM
Icemark's Avatar
Check engine light coming on is putting the car in limp mode. Pull the codes to see what the problem is.
Old Mar 31, 2009 | 05:24 PM
Bluenutz's Avatar
26, 27, 33...omp system and port air solenoid. any way to correct this?
Old Mar 31, 2009 | 05:34 PM
Jeff5808's Avatar
Zoom Zoom
What year rx7 do you have?
Old Mar 31, 2009 | 05:55 PM
Bluenutz's Avatar
1990 GXL--manu. date 09/89
Old Apr 2, 2009 | 02:12 AM
trochoid's Avatar
Old Fart Young at Heart
Hope you're sitting down, a new MOP for the S5s is over 1300 bucks, find a working used one. When the e-mop fails, the ecu goes into limp mode as Icemark stated.
If you don't have a copy of the FSM, download one from one of these sites.
http://www.wankel.net/~krwright/cars/rx7/manuals.html
http://foxed.ca/foxed/index.php?page=rx7manual
Old Apr 2, 2009 | 03:24 PM
Bluenutz's Avatar
does this mean my ecu is bad also? I can still reset it.
Old Apr 2, 2009 | 07:27 PM
RotaryRocket88's Avatar
Top Down, Boost Up
No, the ecu just responds to the bad OMP and puts the engine into limp mode.
Old Apr 2, 2009 | 08:46 PM
dgeesaman's Avatar
While this was on an FD, I have seen an ECU burn up the position sensor of an OMP. So if you have a spare ECU I'd change it just to be safe.
Dave
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
