cold start
Old Mar 29, 2009 | 10:55 PM
RadioX7's Avatar
X MARKS THE SPOT
cold start
I have a 88 vert when its cold the car will start but it wont stay on. I have to keep my foot on the gas till it starts to warm up. ............then its ok. I know nothing is blown and i changed my t.p.s. and it still does it.......... Need help diagnosing this.
Last edited by Rx-7Doctor; Mar 30, 2009 at 01:09 AM. Reason: Recommend you use spell check and learn how to form sentences. :-)
Old Mar 30, 2009 | 07:55 AM
hanman's Avatar
Check the thermosensor operation.
And the cold idle operation.
Old Mar 30, 2009 | 09:40 AM
Aaron Cake's Avatar
Engine, Not Motor
Make sure the cold start cam is not suck.
Check to make sure the BAC is connected and functional.
Check the thermowax assembly and its coolant feed.
Old Mar 30, 2009 | 10:36 AM
Blwn4wrd's Avatar
My car does the same thing... I would check the IAC valve..
Old Mar 30, 2009 | 11:12 AM
Kentetsu's Avatar
Before trying to start, you should press the gas pedal to the floor one time. This sets the "cold start cam" and produces a higher idle speed until warmed up. If you are already doing this, and still having issues, then you'll need to troubleshoot the system...
Old Mar 30, 2009 | 04:12 PM
RadioX7's Avatar
X MARKS THE SPOT
thanx ill try all of them.........
Old Mar 30, 2009 | 05:15 PM
RadioX7's Avatar
X MARKS THE SPOT
yea it still dies out it dose the cold start but when it gose down it dies out then i re-start it and keep my foot on the gass it a lil warm and its cool like it wont die
whinin
Mar 30, 2019 07:53 PM
sherff
Sep 12, 2015 12:22 PM
rx7shirley
Sep 2, 2015 02:11 PM
