What sound do your turbos make?
Old May 26, 2002 | 05:12 AM
jspecracer7's Avatar
1JZ powered
Re: What sound do your turbos make?
Originally posted by TypeR202
My turbos sound like the fluid of an ocean. Don't they usually sound like a hissing/high pitched sssssssss sound?
they sound like....
...HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE
psssssssssssssst
Old May 26, 2002 | 11:14 AM
97VobraVert94FD's Avatar
sssssssssssssssssssssssssssssssssssssssss
Old May 26, 2002 | 11:15 AM
Cypher's Avatar
or sometimes:
pfffffftttttttttttttttttttttttttttttttttttttttt
Old May 26, 2002 | 11:34 AM
black99's Avatar
Lurking..................
mine usually sound like pssssssssssssssss.... whoooooosh..
but now that I have boost leak in my coupler they sound like...
psssssssssssssssssssssssssssssssssssssssssssssss.. .
Old May 26, 2002 | 12:26 PM
spooledUP7's Avatar
There and back again
Mine sound exactly like my old school craftsmen drill motor screaming at the top of it's rotor.
Old May 26, 2002 | 01:52 PM
7-sins's Avatar
thats not paint....
If they sound like a ocean you have a boost leak, check all your couplers.
Old May 26, 2002 | 03:58 PM
daem0n's Avatar
RE-Amemiya in the blood
If they sound like pssssssssssfdfdfdfdsfdsfsdfssssssss, you have something wrong with your turbos :P
Old May 26, 2002 | 09:34 PM
bajaman's Avatar
Constant threat
Mine are sort of a prolonged and intensifying 'whiiiiiiiiiirrrrrrrrrrrrrzzzzzzzzzzzzzz', basically a typical compressor sound, much like the jet engines on my boss's Cessna Citation.....I really, really like hearing the compressors spool ever since I put on the downpipe.
Whistle and hum at the same time, and that is what mine sound like.
Old May 26, 2002 | 09:42 PM
Nathan Kwok's Avatar
Mine sound like a miniature airplane too, basically like something small spinning very fast . If you hear a whoosing sound then you have a boost leak, they used to sound like that until I had the leak fixed. I don't hear any "air rushing" type sounds, just a turbine-like sound and the sound of the engine.
Old May 26, 2002 | 10:41 PM
spooledUP7's Avatar
I like quickly mashing the throttle and letting off when passing someone just to let them know what's up. Open atmospher BOV. Cheap, but gets the point accross.
Old May 26, 2002 | 11:12 PM
ROTARYFDTT's Avatar
Ding King
BLAHAHA, I do that all the time as well. Its so much fun, they look over like WTF was that. The best is going through crowded areas with a bunch of people walking by as you pass them. I just let the BOV sound and see the faces immediately turn.
autoxer
21
May 22, 2019 04:07 PM
elfking
Aug 19, 2015 09:48 PM
rx7jocke
Aug 15, 2015 03:36 PM
WyomingTII
Aug 13, 2015 10:42 AM
