NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Mechanic
Old Mar 27, 2009 | 10:08 AM
charlie1's Avatar
Mechanic
Looking for an independent mechanic for my stock GSL SE 85, in Cols Ohio area?
Old Mar 27, 2009 | 11:45 AM
OneRotor's Avatar
RAWR
what do you need done to it? Most shops hear the word "rotary" or "RX-7" and won't even touch them. I had numerous places refuse to even look into ordering hard-to-find stock parts (including the "Japanese auto specialist" in Ann Arbor, MI) and they all heard "RX-7" and said "we don't deal with them." What help do you need?
Old Mar 27, 2009 | 11:57 AM
mjm4jc's Avatar
84 SE
Try posting your problem and see what the guys say? You may be able to fix it yourself with some help. Just my 2 cents.
Old Mar 27, 2009 | 12:01 PM
OneRotor's Avatar
RAWR
agreed. These are very simple cars to work on. Get advice and dive in head first. I promise, the water is deeper than it looks.
Old Mar 28, 2009 | 08:30 PM
charlie1's Avatar
Thanks all, I have listed a few of the problems on my 85 GSL-SE and tried doing most of the suggestions, but I'm still not getting positive results. Rough idle, and back fire on down shifting and between shifts. Just thought someone who works on these more often maybe able to resolve the issues. Car looks like it belongs on a showroom floor, would like it to run like one. Don't get me wrong you all have helped me solve many other questions, these few issues have me stumped and frustrated.
Steve
Old Mar 28, 2009 | 09:33 PM
mjm4jc's Avatar
84 SE
Steve
Steve,
It sounds to me like you have an intake or vacuum leak somewhere. There is a bullet-proof way to find out if you have a leak: Get yourself a propane torch, you know the ones that are about 12-14 inches in height. Start you car, and then open up the valve on the torch to let out the propane (of course, do not light it). Go around the entire engine with the propane. If you have any leak at all, the engine will change in rpm's. For the hard-to-get places, you may be able to use a long hose with the torch. If you don't want to try this method, you could get a can of WD-40 and spray everywhere, but I think the propane method is better. If you find that you have no intake or vac leaks anywhere, let us know, and we'll try something else.
Mike
Old Mar 28, 2009 | 10:06 PM
charlie1's Avatar
Thanks Mike I'll give it a shot. Idle seems to smooth out more when it's warm. Should I let the car warm up first?
Old Mar 29, 2009 | 09:47 PM
mjm4jc's Avatar
84 SE
Yeah, I would let it warm up and come off of fast idle, so that it is easier to identify when the engine stumbles. Keep in mind that it is somewhat normal for the engine to sound a bit rough when it is on fast idle/warm up. Let me know when you do the propane test.
Mike
Old Mar 30, 2009 | 12:42 AM
ObliqueFD's Avatar
RX-7 Store and Defined Autoworks both specialize in RX-7s and are in Columbus.
SRTx781
Dec 19, 2015 07:30 PM
Jmpabon93
Sep 30, 2015 04:57 PM
