no headlights?
Old Mar 26, 2009 | 01:48 PM
etizz's Avatar
no headlights?
ok so my headlights don't work now....where should i start to look? i tried searching but most were having problems with the lights retracting and such but mine work fine now, just no headlights. helppp
Old Mar 26, 2009 | 01:54 PM
Kentetsu's Avatar
Read the entire thread before you start on this:
https://www.rx7club.com/showthread.p...dlight+cleaner
Old Mar 26, 2009 | 02:07 PM
jinxed4dub's Avatar
lol whats with the first get headlights. this comes up all the time. Kentetsu probably has that threads link on his clipboard at all times.
Old Mar 26, 2009 | 02:10 PM
etizz's Avatar
hmm maybe this explains why i got a spare combo switch with the car...
Old Mar 26, 2009 | 02:25 PM
etizz's Avatar
the highbeams work...i did verify that
Old Mar 26, 2009 | 02:27 PM
Kentetsu's Avatar
I think everyone is pulling their cars out of the snowbanks now, and finding that the switched have had all winter to build up corrosion.
However, thinking about this guy's issue, if you have no headlights at all (low beam, high beam, pulling the lever back) then maybe he should check his fuses before anything else (and fusible links?).
Old Mar 26, 2009 | 05:09 PM
etizz's Avatar
cleaned and swapped my spare combo switch...everything works again! awesomeness! thanks kentetsu!
Old Mar 26, 2009 | 06:02 PM
Kentetsu's Avatar
Glad to hear it man.
Old Mar 26, 2009 | 09:35 PM
slow5oh's Avatar
The Planet Smasher
while we are on the subject of the combination switch. I have tried spraying mine out with electrical contact cleaner to no avail. I have low beams, momentary high beams, but not permanent high beams. Anybody know of a good place to look for a new switch, these fuggers are EXPENSIVE from mazdatrix.
Old Mar 26, 2009 | 09:57 PM
etizz's Avatar
i could clean my other one and test and see if it works and sell it to you lol
Old Mar 26, 2009 | 10:18 PM
slow5oh's Avatar
The Planet Smasher
man, if you wanna go through the trouble, feel free. im not picky, all Im looking for is working condition. I can repair aesthetics. like i said, mine works for everything except for the switched high beams position. momentary high beams and switched low beams work fine. the wiper side works fine too, but unfortunately my wiper motor is bad.
Old Mar 27, 2009 | 06:40 AM
etizz's Avatar
well before i took this one out the only thing that didn't work was the headlights, brights,wipers,washer fluid everything else worked i got it cleaned up, i gotta put it in and test it out, maybe tonight, i'll let you know
renjiv2
57
Jan 25, 2024 03:34 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
