FC retarded idle.
Old Mar 15, 2009 | 06:53 PM
2scoops's Avatar
Driver
Angry FC retarded idle.
sup club, i bought a 87 non turbo rx7 which has been sitting for a while, the car started up, but had a terrible idle which bounces around from 600-1000. when it idles that low, the whole car shakes abnormally. Sometimes the car idles at 1200rpm, and the car does not shake at all. When the car idles high, and i hold the clutch in, and put the car in gear, the idle drops til around 700. The car also dies when i come to a complete stop. ie red light or stop sign. Any help is appreciated, thanks.
Old Mar 17, 2009 | 03:56 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Vacuum leak or bad / out of adjustment TPS.
If the car sat around for a long time, the vacuum lines are probably in bad shape, so start there.
Old Mar 18, 2009 | 06:39 PM
Cutsman354's Avatar
I had similar problems with my 88 NA. It too had been sitting awhile. Check your BAC valve and your air supply valve, but vacuum lines are definitely where I would start.
rgordon1979
40
Mar 15, 2022 12:04 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
qqqqball
11
Oct 9, 2015 07:06 PM
93FD510
Oct 1, 2015 02:00 PM
kuuva86
Sep 28, 2015 05:42 AM
