It might not be an RX-7, but it is a Turbo question.
Old Mar 2, 2009 | 07:34 PM
Madmax670's Avatar
rotors + turbos = bliss
Hey guys, first off, I would like to say that I got rid of my 7s a while ago and undertook a S14/RB26 project. I tried asking my question on another forum and got no help. I am in the process of collecting all the parts, and I now need a turbo. I know from past experience that there are some very knowledgeable guys on here about turbochargers, and was hoping you guys could help me get back to my project.
In doing so, I need a turbo. I was originally going to just go for the GT35R 1.06, but the price is a little outrageous, and I was thinking it may be possible to get a similar performing turbo for less (am I delirious?). Let me begin by first stating my goals. I am looking for a turbocharger that will be able to put out 550-600 HP on this engine at maximum load - hopefully I will negotiate about 450-475 on the streets.
This car will mainly be driven on the streets but with some track time in there occasionally. I want something that isn't outrageously big and laggy, quick response is a must. Also, my manifold is T4 flange. Is there a decent quality turbo out there that can fulfill my requirements that isn't $1500? Am I naive for thinking that this is possible?
Just let me know if there is any other information I have not included.
Thanks in advance guys!
Max
Old Mar 2, 2009 | 07:53 PM
BC-FD3S's Avatar
go ask your question on www.gtrcanada.com in the GTR Tech section.
You will find your answer, lots of single turbo GTR's up here. And a lot of guys who know their ****!
Old Mar 2, 2009 | 09:30 PM
arghx's Avatar
rotorhead
For your price range, you will not be able to afford a ball bearing turbo. All the turbonetics turbos are pretty damn expensive, even the journal bearing ones. So I'd say you should go with a journal bearing Garrett T series.
http://www.atpturbo.com/Merchant2/me...egory_Code=TBN
this T series turbo has the exact same wheel measurements as the GT35 (61mm inducer 82mm exducer), but with a T4 inlet and under $1000. I'd probably go with the .84 hotside and 4" inlet compressor housing if there's enough room.
I suspect this is similar to the GT3574 that A-spec sells (P trim=74mm major).
Old Mar 3, 2009 | 02:26 PM
Madmax670's Avatar
So I am beginning to get the idea that in order to have what I want I am going to have to fork over the money for the 35R.
Have journal bearing turbos gotten better with spool up, or is the difference between BB and journal very vast?
Old Mar 3, 2009 | 03:39 PM
killahrx7's Avatar
dyno queen potentials
master power t70 with .84 hotside should be good
Old Mar 3, 2009 | 04:40 PM
crispeed's Avatar
'Tuna'
Precision 6765.
I've made 682whp on a stock rb26.
Spool is very good.
35'r's are last century technology. If you want a faster spooling turbo than a 35r with greater power capability then go with the precision 6262.
Here's the dyno sheet in the vary same S14 chassis.
Old Mar 3, 2009 | 09:18 PM
arghx's Avatar
rotorhead
what is up with those 62X or 67X series turbos? I can't find much info on them at all, except that they have billet compressor blades. There are no definite compressor maps or charts of compressor and turbine wheel measurements.
Old Mar 3, 2009 | 09:38 PM
crispeed's Avatar
'Tuna'
Those billet turbos are the funk. They put out the same power as one 5mm bigger but retain the spool up.
Old Mar 3, 2009 | 09:49 PM
arghx's Avatar
rotorhead
Maybe they do, but myself and many others won't buy a turbo without more definite information than that.
Old Mar 3, 2009 | 11:41 PM
crispeed's Avatar
'Tuna'
The first number indicaates the compressor inducer's size and the second number indicates the turbine wheel exducer's size in mm.
That's too bad. Stay left behind then!
When you can make 780whp on a 62mm/T3 based turbo and run 8's that's all I need to know.
The 67 Billet has allready made close to 900whp on some applications.
I can't wait to try a 6765 billet on a rotary because I know it will make well over 600whp and spool like an entry level T4 turbo that's needed to have a quick car that can deliver the numbers and not some dyno queen like I've been seeing in here in the last couple of years.
I run these turbos at 47-50 psi and have yet to see one fail in the last year I've been using one.(knock on wood). It's funny you speak about numbers yet we can't keep any on the shelf. Just wish Precision could produce them faster.
Billet madness. The Precision Billet 6765.
Old Mar 4, 2009 | 07:43 AM
killahrx7's Avatar
what's the cost for one of these turbo?
Old Mar 4, 2009 | 07:58 AM
killahrx7's Avatar
never mind just found it.
Old Mar 6, 2009 | 01:18 PM
ScorpionT's Avatar
You dont need a compressor map, they have proven to be reliable and make big power. If you need measurements, ask myself or Crispeed. We both know these turbos very well and have used them ourselves.
You might not buy a turbo without charts and such, but tons of guys have and they are the ones making serious numbers.
MadMax, you can make your power goals on a 6262 or 6265 without breaking a sweat. A 6765 would be overkill if you arent planning for 650+whp.
Old Aug 25, 2009 | 01:18 AM
touturborx7's Avatar
BOOSTLI
man would like to read more about this turbo sounds great.
Old Aug 25, 2009 | 01:24 PM
Insomniac21772's Avatar
https://www.rx7club.com/single-turbo-rx-7s-23/anyone-run-newer-6765-billet-turbo-843781/ there ya go buddy
sherff
Feb 24, 2019 12:09 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
