17x7.5 on an FD
Old Feb 24, 2009 | 06:16 PM
ObliqueFD's Avatar
17x7.5 on an FD
I found a really good deal on some 17" rims, but they are only 7.5" wide. The offset is 48mm. I'm fairly certain they will fit correctly, but I'm worried about the rims being 7.5" wide. Is the half inch loss negligible or should I pass these rims up and look for something bigger?
Old Feb 24, 2009 | 06:21 PM
Miata_mx5's Avatar
Wangan Nasty
Extreme conservative in a tire standpoint and wheel fitment standpoint.
You can run quite a BIT more depending on what you are doing with the car.
Old Feb 24, 2009 | 06:41 PM
gracer7-rx7's Avatar
needs more track time
Don't bother. The deal can't be that great.
Old Feb 24, 2009 | 08:18 PM
Josh18_2k's Avatar
if all you care about is how the car looks... go for it
if you give two ***** about traction, go buy some real wheels (not made for civics)
Old Mar 1, 2009 | 11:52 PM
Halfbridge's Avatar
Brap Brap Brap
They would work but you would most likly have to step down to a 215. I'd let em go
Old Mar 2, 2009 | 12:52 AM
Oun's Avatar
Oun
I can confirm.
dont do it. go for something wider
Old Mar 2, 2009 | 09:20 PM
Halfbridge's Avatar
Brap Brap Brap
Hey ObliqueFD if you want some nice wheels and tires come see me at the Discount Tire at Easton. I can hook you up with some.
Old Mar 2, 2009 | 09:23 PM
Natey's Avatar
That set up will fit perfectly on a Protege/protege5/MSP.
Maybe someone on the Protege forums would want 'em.
mabii
Sep 30, 2005 11:55 PM
Rookie84
Nov 24, 2003 03:41 PM
Cossie
Nov 10, 2002 04:30 PM
