What psi should my oil pressure be at?
Old Feb 22, 2009 | 09:31 PM
BUSTN's Avatar
I am wondering where my oil pressure psi should be at? I am usually around 35 but it goes up to 55-60 when I step hard on it? Is this ok? Thanks and sorry for the dumb question!!!
Old Feb 22, 2009 | 09:34 PM
Scrims's Avatar
Hide the pinball machine
sounds about right....
Old Feb 22, 2009 | 11:39 PM
JCurry's Avatar
Shpee
hmmm mine runs like 30 at idle(900 rpms) and almost 60 at 70 in 5th gear
Old Feb 23, 2009 | 06:39 AM
Go48's Avatar
Here's what Mazda says about that, 64-78 psi at 3K rpm. When warmed up, my '90 GTU ran around 65 psi at or above 3K rpm, and my '91 Turbo runs around 60 psi. So, if your engine runs around 60 PSI, it should be fine. Keep in mind that Mazda is using a special tool to measure the pressure which is probably more accurate than the sender/gauge in the car.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
andyvideopro
Aug 20, 2015 10:55 AM
