TriPower dash top dual gauge pod
Old May 23, 2002 | 11:48 AM
CrispyRX7's Avatar
Polishing Fiend
Finished my install and I don't think it turned out half bad if'n I don't say so myself
Crispy
Old May 23, 2002 | 11:55 AM
CrispyRX7's Avatar
Polishing Fiend
One more pic....
Old May 23, 2002 | 11:57 AM
CrispyRX7's Avatar
Polishing Fiend
Nordskog digital gauges. Both have a peak hold function with the fuel pressure having both a low and hi peak hold. And they are inexpensive too!
Only $35 each!!!! I have them wired into a separate toggle switch so I can turn them off if I want too.
Crispy
Old May 23, 2002 | 12:33 PM
saiyan's Avatar
I like the gauges too, but are they accurate?
Old May 23, 2002 | 12:42 PM
ttpowerd's Avatar
HARRRRRRRRR
Looks really nice. I have a digital water temp gauge. Looks just like those...probably the same brand.
Old May 23, 2002 | 12:45 PM
Jason's Avatar
The one
I have a bunch of the Tripower gauge pods in stock.
Jason
www.rx7store.net
Old May 23, 2002 | 02:38 PM
CrispyRX7's Avatar
Polishing Fiend
Nordskog - Intellitronix - Cyberdyne. I beleive they are one in the same with Nordskog being the manufacturer and the latter two being rebadged gauges.
I'm digging for accuracy info but I doubt they are any less accurate than most gauges on the market currently short of the $300 aviation type gauges.
I'll let you guys know what I find.
Crispy
Old May 23, 2002 | 03:04 PM
7-sins's Avatar
thats not paint....
Very sweet, any links to buy those gauges?
Old May 23, 2002 | 03:13 PM
CrispyRX7's Avatar
Polishing Fiend
Summit Racing - domestic territory I know but they had the best prices. Don;t forget the cost fo the sender/sensors too IIRC the fuel pressure was $35 and the temp sensor was $15
Crispy
Old May 23, 2002 | 06:00 PM
Sarge's Avatar
Re: TriPower dash top dual gauge pod
Crispy
Nice job. Is that your dash speaker hole they are sitting in?
Old May 23, 2002 | 08:08 PM
Qball's Avatar
Comp Yellow Mica
Re: Re: TriPower dash top dual gauge pod
yes they fit in the speaker housing.. and you can buy them online.
Old May 23, 2002 | 09:30 PM
bajaman's Avatar
Constant threat
Not sure about the automotive gauges, but in the marine/boating world, Nordskog gauges are THE standard by what others are judged by. But....they are very high dollar.
I too saw those gauges and other Nordskog's in the SUMMIT catalog.....hmmm. Not bad, not bad at all.....
Old May 24, 2002 | 05:02 PM
I have the same guages in my turbo-MX5. The boost guage is totally inaccurate. reads 1psi with the key on and not running
Old May 24, 2002 | 07:26 PM
sunnyxwala's Avatar
"I used to have one"
From: dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS
hey crispy, where di u buy those guages from?
Old May 24, 2002 | 09:26 PM
rx7_lover's Avatar
someone mentioned previously...
http://www.summitracing.com
goto performance parts and look for gauges/sensors...
sYnth.
Aug 19, 2015 06:27 PM
