Going Turbo from N/a
Old Feb 21, 2009 | 10:38 AM
Happymanatheart's Avatar
Question Going Turbo from N/a
Before you tell me its somewhere else just read.
On a turbo engine swap in a n/a body, leaving the n/a tranny, drive shaft, etc.
I have seen many people talk about counter weights, but I can never tell who knows what there talking about and who doesn't . From some advice I would put a n/a flywheel on my turbo s5 and n/a clutch and flywheel. And if the flywheel is after market I have to buy either auto tranny counter weight since separate, or an after market one. If I just want a stock flywheel the stock manual flywheel has counter weight in it? Okay is this right?
( I have searched and read other post on this topic)
Old Feb 21, 2009 | 11:31 AM
jake1191's Avatar
Pop Pop BANG FIRE!
you can use the stock S5 n/a flywheel to do the conversion. You cannot use the stock S4 flywheel though. Aftermarket you would need the corresponding automatic flywheel for the engine. Meaning S4 stays with S4 only and S5 with S5 only
Old Feb 21, 2009 | 12:40 PM
RYS13's Avatar
Aftermarket flywheels require the auto-tranny flywheel counterweight. Stock manual-tranny flywheels have the counterweight incorporated into their design. Most aftermarket flywheel counterweights are from Mazda directly. If you plan on using an NA transmission for a Turbo engine, I would highly recommend ugrading the clutch.
Old Feb 21, 2009 | 04:43 PM
dawicka2's Avatar
well rested,buffet o food
I have seen many people talk about counter weights, but I can never tell who knows what there talking about and who doesn't . From some advice I would put a n/a flywheel on my turbo s5 and n/a clutch and flywheel. Yes that is correct. Your s5 na flywheel and na clutch (upgrade like mentioned above) go on the s5 t2 engineAnd if the flywheel is after market I have to buy either auto tranny counter weight since separate, or an after market one.yes s5 auto counter weight or s5 act..whatever If I just want a stock flywheel the stock manual flywheel has counter weight in it? Yes, that is correct, your stock na s5 flywheel has the counterweight built in for your s5 t2 engine Okay is this right?
Good luck with the build, man,
John ny
Old Feb 22, 2009 | 12:03 AM
Okay It's a n/a standard Tranny. I have to upgrade clutch to prevent slippage, yes. And yes I know not to mix and match s4 and s5 do to the diff weights of rotors, and such. So... If I use n/a aftermarket flywheel I can snag a automatic counter weight since not built in, for the manual tranny. Or I need to buy a Mazda after market counter weight.
Old Feb 22, 2009 | 12:04 AM
Thanks for luck! I'll try to keep posted on build, I just need clutch and I can start putting everything togeather!
Old Feb 22, 2009 | 12:04 PM
jake1191's Avatar
Pop Pop BANG FIRE!
I would personnally not buy all the high performance N/A stuff. It will be a waste down the road when the trans or rear blows out on you from the turbo motor.
hotshot2014
Jul 18, 2017 02:30 PM
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
rxmiles
Aug 24, 2015 02:07 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
