Dyno Day 2/28
Old Feb 18, 2009 | 07:20 PM
rotorette's Avatar
That Chick
Dyno Day 2/28
The local volvo guys are doing a dyno day and there is some room for a couple more cars if any of you are interested in seeing your numbers.
It's at Kito in Ballard
SATURDAY FEB 28TH 2009 @ 11AM
COST IS $75 PER PERSON
AFR - YES!
AWD - YES!
Let me know if you are interested and I'll add your name to the list.
Here's the Volvospeed thread. http://volvospeed.com/vs_forum/index...c=111133&st=80
Some tips:
Before you arrive:
Please follow these instructions to ensure that your tuning session goes smoothly.
- Follow the Pre-Dyno Session Check list below.
- Arrive at least 20 minutes early.
- Arrive with at least ½ tank of fuel or more.
- Be flexible. Your scheduled slot may be pushed forward or back depending on how other tuning sessions progress.
Pre-Dyno Session Check list:
A few days before your scheduled dyno session please do a visual inspection by looking under the hood of your vehicle and checking the following:
- Fluids: Check that all fluid levels are correct and not leaking:
- New Engine Oil
- Coolant
- Transmission
- Brake Fluid
- Spark Plugs: Make sure that you have good plugs and the gaps are up to spec. Bad plugs and/or plugs gapped incorrectly will lead to issues during your dyno tuning session.
- Belts: Make sure that all belts are in good condition, replace if necesessay.
- Hoses: Check and make sure that all hoses are tight and properly connected.
- Boost control: Make sure your boost controller is working properly.
- Intake: If you have an oiled air filter, check that the MAF sensor is clean. An oiled MAF sensor will provide inconsistent readings and won't allow us to properly tune your vehicle.
- If you have a standalone, make sure you bring all necessary accessories required for tuning (software, cables & etc.).
- Exhaust System: If we are going to be reading AFR's from the tailpipe, it is extremely critical that there are no leaks. Leaks will skew the AFR readings and will not allow us to properly tune your vehicle.
- Wheels & Tires: Make sure that they are balanced and have sufficient amount of tread. NO SNOW TIRES
Old Feb 18, 2009 | 07:46 PM
Hyper4mance2k's Avatar
The Shadetree Project
FYI Kito won't let you drive your own car on the dyno, so if you're un comfortable with letting someone else bash on your car then I wouldn't go there.
Old Feb 18, 2009 | 09:27 PM
Upgrayedd's Avatar
Double Dose
I will probably attend but I don't wanna dyno my stock Volvo
Old Feb 18, 2009 | 11:47 PM
endneu913's Avatar
Turbo Waggin
Well be coming just for fun.. to hang out... if nothing else is going "on" aka work.
Old Feb 19, 2009 | 12:21 AM
woundup7's Avatar
The Outsider
Thats true Kito doesn't let you drive your own car, gay, I know.
Old Feb 19, 2009 | 10:17 PM
Upgrayedd's Avatar
Double Dose
Oh snap I just realized I'm working on that Saturday... But I should be off by like 9am so I should still be good to go
Old Feb 19, 2009 | 10:57 PM
woundup7's Avatar
The Outsider
Tim how much you trying to get for the SHO,? Is it driveable.?
Old Feb 19, 2009 | 11:29 PM
Upgrayedd's Avatar
Double Dose
Yeah it's drive-able but the seal definitely needs some fixing asap. I'm asking $1000 but I'm not firm whatsoever on the price. The transmission is still mechanically sound, it's just bleeding pretty badly from the main seal it appears
Old Feb 23, 2009 | 11:07 PM
Upgrayedd's Avatar
Double Dose
Still 6 open spots for the dyno day according to Volvospeed
Old Feb 24, 2009 | 01:11 AM
endneu913's Avatar
Turbo Waggin
Well.. in an effort to be a responsible manager... i will be working this sat... Friday off for garage funzies, Sun off for AutoX class... I hope the teacher doesn't spank me. Speaking of, chris! i need your help... since nowadays i just ask you instead of figuring out myself... Remember last week when i told you my clutch pedal got stuck down several times while on the course? Can you give me a hand in figuring out wtf's up? That pretty much takes the fun outta AutoX
Old Feb 25, 2009 | 11:42 PM
woundup7's Avatar
The Outsider
Grae, you can always autocross the -R-. Seriously not going to be at the dyno, who am i going to cry to when my wagon only busts out a 167 fwhp. lol
On a serious note the volvo crew is one short of making 10 people for the dyno, if you want to come out and see what all those mods made horse power wise please do, I will buy you a 23 oz at Rocko friday night. Thanks
Old Feb 26, 2009 | 05:29 PM
woundup7's Avatar
The Outsider
ttt
Old Feb 26, 2009 | 06:15 PM
Upgrayedd's Avatar
Double Dose
Chris buy me a 23oz cuz I'm gonna be there Saturday What time is your dyno spot scheduled for? I work 6-9am Saturday and I may have to do a little bit of moving if I don't get off work early Friday and have no time to move
Old Feb 26, 2009 | 07:49 PM
woundup7's Avatar
The Outsider
Hopefully I will be one of the first couple on there. got **** to do.
Old Feb 27, 2009 | 01:52 PM
i might come out just to watch.
Old Feb 28, 2009 | 08:48 AM
Upgrayedd's Avatar
Double Dose
yes Adrian come out!
Old Mar 1, 2009 | 07:29 PM
i was going to go, but turns out it wasn't today. LOL!!!
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Clacor
Sep 11, 2015 08:36 PM
RxglassJAw
NE RX-7 Forum
Sep 10, 2015 07:35 PM
SakeBomb Garage
SakeBomb Garage
Sep 7, 2015 03:32 PM
