Haltech Trouble zeroing my timeing
Old Jan 24, 2009 | 04:31 PM
Twins80s's Avatar
I
So I was trying to zero the timeing today on my 2nd gen non turbo. I have the timeing locked to -5*. With the timeing light on t1 the -5* mark is almost 90* off. The mark is over by the spark plugs. Mind you I have not touched the hub or cas since the car ran last. Well the problem is now as I retard the timeing via timeing angle value the car runs rough and stalls. However when I advance it the car runs smoother.
Do you guys have any ideas what could be up?
I am also running a 13bt base map for my na since I have not found a stock port map for na.
Old Jan 25, 2009 | 02:42 PM
Twins80s's Avatar
I
Well I pulled the hub and saw that it can only go on one way. Pulled the cas and it was set right. I am still confused. I tried a na map today but even with the triger angel value at 100 i was still alittle short of reaching the timeing mark.
Old Jan 25, 2009 | 02:58 PM
BDC's Avatar
BDC
BDC Motorsports
Use the Leading 1 plug wire.
What are your ignition settings?
B
Old Jan 25, 2009 | 03:42 PM
Twins80s's Avatar
I
I have tried both the leading 1 and trailing 1
this is the map I am useing
E6K - Map, Stock Motor, stock injectors, 3bar MAP sensor, Stock Ignition/Coils.
befarrer
Microtech
Aug 22, 2015 05:52 PM
ppritchard
Interior / Exterior / Audio
Aug 21, 2015 06:02 PM
Marty RE
Aug 13, 2015 11:19 AM
