sensors the problem?
Old Jan 23, 2009 | 02:06 AM
revox7's Avatar
Rotary AE86
i just installed a new na engine into my na s5 but i broke the temp sensor a the bottom of the rad. and the sensor that goes in the oil pan, also i eliminated my air pump, i started the engine and it idles erratically and kinda coughs would it be the sensors the lack of air pump?
Old Jan 23, 2009 | 02:12 AM
dawicka2's Avatar
well rested,buffet o food
Lack of airpump wouldnt make it cough if blanking plate is mounted properly. When you say new engine, i assume you mean used and new to the car..... not mazda reman or rebuilt. Did you hear this engine run prior to the install? I would also check for a vaccum leak somewhere too.
John ny
Old Jan 23, 2009 | 08:37 PM
eff_three_see_es's Avatar
lycanthrope
is this the new 2nd gen tech section?
ZacMan
Sep 19, 2015 09:20 PM
vmerino
Sep 5, 2015 11:26 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
