walbro 255 lph into fc problems
Old Jan 22, 2009 | 09:07 PM
MIDWESTSTYLE's Avatar
when i turn my car into the "on" position i do not hear the fuel pump kick on...but when i am cranking my car the pump turns on...shouldnt it turn on when the key is in the "on" position? what could be the problem???
Old Jan 22, 2009 | 11:07 PM
Icemark's Avatar
Only should turn on during cranking and when the engine is running. Not just by turning the Key on.
Old Jan 26, 2009 | 07:48 PM
the "on" position that i am speaking of is the one before the car starts cranking. which is the same position the key is in while the vehicle is running.
is the 1300cc.com fuel pump rewire write up the same for both s4 and s5??? are there any other write ups??? i have searched and that is the only one i can find.
Old Jan 27, 2009 | 08:57 AM
Aaron Cake's Avatar
Engine, Not Motor
The fuel pump only runs if the car is running or cranking.
The fuel pump rewire is for all TIIs.
Old Jan 27, 2009 | 10:24 AM
philiptompkins's Avatar
yeah, the "ON" position isn't what makes the fuel pump turn on, I'm pretty sure the air puling though the MAF turnes the pump on after cranking is done.
Old Jan 27, 2009 | 04:38 PM
thank you guys..i figured it out!!!!!!
tidanb0utch
11
Oct 7, 2015 07:36 AM
vmerino
Sep 5, 2015 11:26 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
