NON SEQ. (How To)
Old May 21, 2002 | 12:03 PM
Slither's Avatar
Thanks for the info, thats one mod Ill probably be doing as soon as i get my FD
Well, after i get a new ecu of course
Old May 21, 2002 | 02:24 PM
nocab72's Avatar
03 Cobra Killer
Thanks Ryan, the 6 short sentences on Robinettes site didn't help me out much on what to expect.
k
Old May 21, 2002 | 02:37 PM
Street King's Avatar
*** Bless Texas!
HURRY HURRY HURRY
Old May 21, 2002 | 02:40 PM
neevosh's Avatar
The Dude Abides
There's a how-to in the archive already.
Old May 21, 2002 | 02:49 PM
jpandes's Avatar
Thanks Ryan! I was one of the 50 who pm'd you! I'll wait till you get pics up on your site...
John
Old May 21, 2002 | 03:19 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Everybody hates to search! Comeon now you should know that. I rode in Ryans Fd today for the first time since he did this mod. I was impressed with the smoothness and consistancy of the boost. I say that most will like this if you are sick of spikes and boost creep. I personaly will stick with sequential for the time being as I dont have a mid pipe yet. Plus I kindof like the fell of 2ndary coming in line. You should all thank Ryan for hooking you up.
Old May 21, 2002 | 03:24 PM
7-sins's Avatar
thats not paint....
I want to add for anyone with the Power FC. You are suppost to switch your lines going to the wastegate solenoid (the one on the right) to the precontrol solenoid (one of the left) for boost control. Also in the PFC turn the sequential setting off.
Ryan, any luck tuning the PMS? I know you can have a lot less lag since I get full boost at 3700rpms.
Old May 21, 2002 | 03:31 PM
7-sins's Avatar
thats not paint....
Thats good, you should be able to get it around that range. I bet the streetport pumps out some more exhaust flow. I think the PMS computer still uses the wastegate solenoid for boost control.
Old May 21, 2002 | 03:42 PM
Rotarius's Avatar
I was able to lock the TCA open with a piece of alumimun metal 1/2x3inch and a screw bolting it to the heat shield. Then i used a spring i go at the junk yard to control the WG at 10psi constant. Works great for me.
Old May 21, 2002 | 03:45 PM
7-sins's Avatar
thats not paint....
That would be a great idea. You could even drill holes in it and attach were the TCA bracket is.
Old May 21, 2002 | 03:54 PM
Rotarius's Avatar
Just got to remember to unplug the vac. & press. lines up by the upper manifold or the force will eventually bend the strip of al.
Old May 21, 2002 | 03:55 PM
gzon's Avatar
what is the advanteges in going non-seq? and what is the disadvanteges? How will the car feel compare to seq?
Old May 21, 2002 | 04:12 PM
Rotarius's Avatar
Do a Seach on this site. Theres a lot of good info so that way you can draw your own conclusion. Good luck.
ls1swap
Jun 3, 2024 03:25 PM
LetsGO7
Oct 19, 2004 09:34 PM
smg944
Oct 12, 2004 09:31 PM
Dont_Be_A_Rikki
33
May 21, 2002 05:21 PM
