help finding where these go s4 tII
Old Jan 21, 2009 | 09:02 PM
MIDWESTSTYLE's Avatar
this plug...have no clue where it goes to....
it has one wire going to it
and what do i connect this to???? or can i cap it off.
thanks
Old Jan 22, 2009 | 11:05 PM
Icemark's Avatar
Hard to see in your pictures, can you tell us the wire colors?
Old Jan 22, 2009 | 11:14 PM
RotaryRocket88's Avatar
Top Down, Boost Up
The top looks like the coolant temp sensor wire, which plugs in under the oil filter.
And the bottom is the air inlet for the BAC valve. If you have no BAC, then yes, you can cap it. I'd use a hose clamp on whatever you cap it with too.
Old Jan 22, 2009 | 11:25 PM
it is a yellow wire with white tracer
Old Jan 22, 2009 | 11:36 PM
found where it all goes....thanks
rotor_veux
Aug 31, 2015 07:49 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
