OMP and Premix
Old Jan 21, 2009 | 09:28 AM
dmolchanoff's Avatar
Is That A 4 Rotor?...
OMP and Premix
hey guys i was wondering i own an 86 GXL and i was wondering would it cause extra carbon buildup if i still use the stock OMP and premix my gas....or will this acutally help burn out carbon? im pretty sure it isnt going to hurt anything just making sure before i do.
Old Jan 21, 2009 | 07:16 PM
farberio's Avatar
NASA-MW ST4
You can premix with the OMP, I don't know what it will do for carbon. Probably not much of anything unless you are premixing with Amsoil.
BTW, premixing with omp active is 4oz per tank of gas.
Old Jan 21, 2009 | 08:22 PM
cool thanks... anyone else experience problems while premixing and keeping the stock OMP?
Old Jan 21, 2009 | 09:37 PM
alexdimen's Avatar
TANSTAFL
Going on 30k miles with 128:1 and OMP. Inspection though exhaust ports showed very clean rotors. Compression and vacuum been stellar every time it's been tested.
Old Jan 22, 2009 | 09:10 AM
Aaron Cake's Avatar
Engine, Not Motor
Why do you want to premix while still using the stock pump?
Unless you are tracking the car, this is unnecessary.
Old Jan 22, 2009 | 08:05 PM
trochoid's Avatar
Old Fart Young at Heart
Add a can of Seafoam to the tank every oil change. That will clean out an reduce carbon build up.
Andrew7dg
Aug 6, 2017 01:41 PM
