Secondary turbo low boost, primary spike
Old May 20, 2002 | 06:43 PM
Rx-7$4$me's Avatar
93 base with 71xxx miles on original engine/turbo's. When I floor it in first It goes up to 10, sometimes to 11 and holds till secondary when it slowely drops off down to around 6psi till redline, in second same thing, in third it will drop to about 7 psi as well as 4th. precat still on, and since it has high milage could it be pretty clogged and be causing it? I have a downpipe in my garage waiting to go on. What do you suggest?
Stevo
Old May 20, 2002 | 06:50 PM
Rx-7$4$me's Avatar
When I shift it only goes back up to around 7psi, but its also above 4500 rpm so its still the secondary.
Old May 20, 2002 | 07:00 PM
ROTARYFDTT's Avatar
Ding King
I have the same problem with an aftermarket DP. It really sucks because my car is soooo much slower. Anyway, a clogged pre-cat could be the cause so put in the DP and see what happens. Unfortunately I do not know the cause of my boost problem so that is the only suggestion I can give you.
Old May 20, 2002 | 10:10 PM
P'cola FD's Avatar
Hamado things my way!
Did it happen all of a sudden, or has it slowly gotten worse? I'd guess it to be a control system problem. Check the solenoids/hoses/actuators for the turbo control actuator, charge relief, and charge control.
cristoDathird
28
May 30, 2019 08:47 PM
dkwasherexd
May 27, 2017 04:51 AM
