Sponsored by: CARiD
rotor differences ???
Old Jan 12, 2009 | 02:42 PM
samseed12's Avatar
Member
How can u tell the differences between the 13b n/a, 13b turbo and the 13b-rew?
I got a set in the mail and i dont belave they are the same ones from compareing my old ones. The sides where the oil rings go are diffrent. They look to be a pair of 13b turbo 2s from what a friend said, but im building a 13b-rew.Would those work?
I tried searching online for information on it but ive had no luck.
Old Jan 12, 2009 | 04:19 PM
diabolical1's Avatar
S4 rotors have casting flash in the recesses, whereas S5+ have machined recesses.
go to Mazdatrix and double-check the weights, but i think if the rotor you're getting is an S5 T2 rotor, then it should work in your REW. if it's anything else, then you've officially got issues.
Old Jan 13, 2009 | 12:00 AM
samseed12's Avatar
Member
cool i found out, thanks!
jsesq
27
Sep 25, 2015 11:10 AM
yetter227
20
Sep 5, 2015 11:57 PM
VTECthis
Aug 24, 2015 09:01 PM
