S5 Tail Light Gasket #?
Old Jan 12, 2009 | 01:23 AM
lele73's Avatar
15U24
Can anyone help me out? I need to order new Tail light gaskets but i don't know the part numbers. I tried to look it up but couldn't find it at all. thanks
Old Jan 12, 2009 | 07:02 AM
adeenoki's Avatar
Exempt_revisioN
there's a gasket for the tail light? maybe that's why mine is leaking lolz
Old Jan 12, 2009 | 05:53 PM
Icemark's Avatar
I am assuming you have a coupe, and not a convertible...
The Taillight gasket P/N for all FC's is FB01-51-156
The license plate light gasket P/N is FB01-51-157
You need two of each to replace the gaskets on all the rear coupe lights.
Old Jan 12, 2009 | 06:00 PM
RotaryRocket88's Avatar
Top Down, Boost Up
RX7 parts fiche: http://www.rotaryheads.com/PDF/2nd_gen/index.html
Picture is attached. It's in the "Body" section. (note: 2 pages overlapped)
Old Jan 13, 2009 | 08:08 PM
lele73's Avatar
15U24
awesome thanks. i did look at the fiche's but i really couldn't figure it out. but thanks again!!
another question is.... do you know why the lenses separate? it looks like a common thing with the FC. how can i avoid that? im tired of water entering the housing through the separation.
Old Jan 14, 2009 | 03:47 PM
Top Down, Boost Up
The lens is held on w/ some epoxy. You can heat the whole tail light assembly in an oven (I think people use around 150-200 degrees?) or with a heat gun / hair dryer, then pry the lens off. While the epoxy is hot, move it around for a better seal, then press the lens back on. This should help reseal it so water stays out.
Old Jan 14, 2009 | 06:24 PM
Icemark's Avatar
actually a type of Hot glue... not epoxy...
And if it is leaking, it has been taken apart and not put back together at the right temperature.
Old Jun 17, 2009 | 04:06 AM
phound69's Avatar
question, does that p/n apply to verts too?
Yes I realize IceMark (RX-7 Master/God) said all FCs, but he also specified coupe over convertible. So, just looking for clarification.
Old Jun 17, 2009 | 11:49 AM
Top Down, Boost Up
The parts fiche doesn't specify that the PN is for coupe or vert only, and that gasket covers a common area of the two types of lights. They only differ on the inner edge, where the vert lights stop and the coupe lights extend further. I would assume it's the same, but you can look through the fiche yourself too.
alemmons
Sep 4, 2015 09:34 AM
