Vacuum: Replace v. Remove
Old Jan 11, 2009 | 02:07 PM
1NSIGHT's Avatar
I Used to Park Cars
I have a lil extra money to spend on my 86 NA S4.
Should I replace the hoses or get rid of the ones I can. Why or Why NOT?
The car is daily driven and stock w/ the exception of premium wires and plugs.
Old Jan 11, 2009 | 09:25 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Are the vac lines old and in need of replacing? If so, then go ahead. It shouldn't cost you more than ~$30 to buy enough hose to redo the engine bay.
There's no performance gain from removing emissions equipment and the hoses associated with them, so the only reason to get rid if them is to clean up the engine bay. If that's your goal, then do some searches for "emissions removal" to find out how to do it properly. Obviously, if your area does smog checks, you'll need to keep them.
Old Jan 12, 2009 | 06:59 AM
adeenoki's Avatar
Exempt_revisioN
don't know much about those cars but if you have a nest of lines like the 3rd gen, it would just bug me not to take it out and minimize the lines.
streetlegal?
Mar 17, 2022 02:46 PM
Th0m4s
Feb 26, 2019 02:04 AM
rotor_veux
Aug 31, 2015 07:49 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
