Quick question: Are ball joints replaceable?
Old May 20, 2002 | 10:39 AM
inittab's Avatar
I read your email
Just wondering if the ball joints are replaceable in my 85 GS control arms. Victoria British sells ball joints but Mazdatrix sells the control arm with the ball joints. Can someone clairify this? Thanks!
Old May 20, 2002 | 01:00 PM
Barwick's Avatar
SCCA Rookie
I don't know, but I just replaced both the inner AND outer tie rod, along with the threaded rod that connects them, all for well under $100. Just get 'em all changed would be my opinion.
Old May 20, 2002 | 01:04 PM
inittab's Avatar
I read your email
I'm in the process of replacing all my tie rods at the moment. Problem is... my ball joint boots are split and probably need replacing. To save money I would rather just replace the ball joints than the whole control arm but upon inspection I'm not sure if the ball joints are replaceable without getting the whole arm.
Old May 20, 2002 | 06:40 PM
CrazyJoe12a's Avatar
I replaced the ball joints on mine when i got it. didn't have to replace the entire control arm. Just rent a ball joint press....
Old May 20, 2002 | 06:45 PM
peejay's Avatar
Old [Sch|F]ool
The ball joints are not replaceable. When they get loose, you have to get another car.
Old May 20, 2002 | 06:52 PM
So are they replacebale or not?. Ive heard they are!.
Old May 20, 2002 | 07:16 PM
inittab's Avatar
I read your email
Ah man!!!! That's what I was afraid of.
Old May 20, 2002 | 07:18 PM
Directfreak's Avatar
I am a Jeeper Now.
Dude, take it with a grain of salt. As you can see from several posts above, people HAVE replaced them.
Old May 20, 2002 | 07:21 PM
inittab's Avatar
I read your email
Yeah, but I just got my rex and now I gotta get a new one.
Old May 20, 2002 | 09:36 PM
peejay's Avatar
Old [Sch|F]ool
I'm just being a ******, folks...
The problem is the balljoints press into basically sheetmetal. At the one shop where I worked every time we replaced a Mazda press-in ball joint, it wouldn't press in, just rattle around loose in there. UNfortunately, most of the control arms we had problems with (626/MX-6/Probe) have been DISCONTINUED.
Old May 20, 2002 | 10:19 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Heres what I did Knocked it out and replaced with a new one, then welded the sleeve to the arm. Mind you I get one shot at it, but i can find plenty of worn out arms
Peejay is right it never stays in there tight Unless you tack weld it
Old May 21, 2002 | 10:56 AM
inittab's Avatar
I read your email
Thanks for the great info guys! I knew you'd pull through for me. Since I don't have a welder and I found a source of control arms for $101 each. I think I'll go that route. Again thanks!
Old May 22, 2002 | 12:16 AM
Kill No Cone's Avatar
If you get the ones from Mazdatrix, they will no charge you to press in new bushings. So, I sugest that you get their control arms and have them press in urathane bushings. It sounds like your changing everything else.
Old May 22, 2002 | 10:34 AM
yayarx7's Avatar
Are you Nucking Futs?
Where are you getting yours at $101?
Old Jul 11, 2002 | 11:49 AM
85gs's Avatar
I'm getting ready to replace my entire front and rear suspension. I've got RB springs and Tokiko Illuminas along with a polygraphite front end rebuild kit from PST(containing new ball joints). CrazyJoe12a replaced his balljoints as did Mike-P-28 (adding the tack weld to hold them in place). Have others had good results with replacing the ball joint and not the entire control arm? Any areas to pay particular attention to? Any advice is greatly appreciated!!!!!
Old Jul 16, 2002 | 06:16 AM
85gs's Avatar
Any other thoughts?????
fjwheeler
22
Jan 9, 2022 01:02 PM
vipernicus42
Mar 7, 2016 04:57 AM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
