oil pressure ?
Old Jan 8, 2009 | 12:14 PM
Paul Spickard's Avatar
Question oil pressure ?
Okay i need some help my car is reading low oil pressure does that mean i just need to put more in the car or is there an oil leak. It sparadicly beeps and the oil light turns on then off quickly. It also beeps when i turn a little hard whats that about?
Old Jan 8, 2009 | 01:49 PM
Aaron Cake's Avatar
Engine, Not Motor
Low oil pressure most often just means a bad sender. Check the wire connection to the sender, and verify with another gauge.
HOWEVER, if the oil light blinks and the buzzer sounds, then CHECK THE OIL LEVEL.
Old Jan 9, 2009 | 10:17 AM
celbii's Avatar
jackie chan > chuck norri
Question Aaron, where exactly is the sender at, I would like to check mine.
Old Jan 9, 2009 | 12:01 PM
Yeah the oil was almost empty so i filled that and tightened a belt and the car overall is running better.
Old Jan 9, 2009 | 02:39 PM
mar3's Avatar
Administrator
Side of the oil pan for a 12A....
Mario III
Old Jan 9, 2009 | 02:55 PM
celbii's Avatar
I just found it on my fc, I kept missing it because it was all the same color from oil down there lawlz. Found it by tracing the wires from the clutch slave
Old Jan 9, 2009 | 06:50 PM
diabolical1's Avatar
mar3 is correct for the level sender.
however, if you guys are looking for the pressure sender, it's just under where the filter is mounted.
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
