NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
emissions help please!!
Old Jan 5, 2009 | 03:19 PM
Agent-7's Avatar
prodigy racing
CT emissions help please!!
i just failed my emissions test, the HC level was 1004 and Co level was 1.48, the limit for HC is 231 and 1.23 i think for Co. What do i do to pass? and what are things i need to check for? I got 30 days to retest, any help is much appreciated!
Old Jan 5, 2009 | 04:45 PM
LoneCorp's Avatar
Iam LoneCorp Hear Me Roar
This isnt much help since i've never had that (i think my cars to old) but that def doesnt sound good im going to pass this link to a few people on aim and hopefully u can get a answer!
Old Jan 5, 2009 | 05:00 PM
Joker1337's Avatar
Water Boy
Tune the car up per FSM would be my suggestion.
What's your F/A mixture running? Leaning it out might help a bit.
Is your timing good? (I don't have clue how you adjust that on an FC.) If it's off, CO should be adjustable slightly by advancing the timing iirc.
How old is the cat?
Does CT have a repair waiver? (E.g. in MD if you spend $350 on emissions parts you get out of jail, for $350.)
You might get better results (if you haven't already) posting in the FC forums.
Old Jan 6, 2009 | 03:22 PM
Agent-7's Avatar
prodigy racing
yeah i have a stock s5, didnt do a thing to the engine, so i dont know why its not passing.
Old Jan 6, 2009 | 10:50 PM
jaison's Avatar
Sounds like it's running rich. Don't know much about your car, but when I had trouble passing emissions, it turned out to be a simple O2 sensor that needed to be replaced even though it was not throwing any codes. I also had high HC and CO readings.
Old Jan 9, 2009 | 01:45 PM
Agent-7's Avatar
prodigy racing
thanks im gonna go get an O2 sensor today and see how that goes.
Old Jan 9, 2009 | 06:01 PM
FCNAred's Avatar
just idle sniffer or do they do roller dyno? I passed earlier this week in MD by lowering the suspension such that it couldn't fit on the emissions dyno, instant 2 year waiver. I didn't even have to pay the $14.
Old Jan 10, 2009 | 01:07 PM
Agent-7's Avatar
prodigy racing
they do a dyno roller, haha good job man
Old Jan 10, 2009 | 02:55 PM
Hitokiri_Gensai's Avatar
RHD ftw!
bah emissions... find a shop that'll botch the results. but you didnt hear that from me >.>
kidding. xD
best bet, check the cats, make sure they're not worn out, then check your a/f ratio, make sure its within spec and then just bring it back, best bet tho, SAFC and lean out the system a bit.
Old Jan 10, 2009 | 03:11 PM
Delicious's Avatar
two words
methanol trick
Old Jan 11, 2009 | 12:49 PM
John64's Avatar
What?
2 gallons of denatured alcohol right before you test. As soon as your done fill her up with high test! I went from a gross polluter to not registering much at all. I did this all with out the airpump also!
Old Jan 13, 2009 | 11:41 AM
TitaniumTT's Avatar
This is something that I'm going to worry about in the near future......
Did you have cats for that test John?
Old Jan 13, 2009 | 06:29 PM
LoneCorp's Avatar
:o Everytime i get this done they just look at my lights and fires and pass me -.- gotta love new york
Old Jan 19, 2009 | 09:04 PM
John64's Avatar
What?
Yeah, I put my cat back on.
Old Jan 19, 2009 | 09:38 PM
helghast7's Avatar
F yo couch!
hmmm your HC levels lead me to believe you own a rotary
not really much you can do on an FC,
check for vaccum leaks, extra air after the AFM could cause the engine to run rich because it is unmetered air, the pcm sees lean and richens it up,
exhaust leaks, depending on location they sometimes can alter emmissions readings
if your cat is actually working, clogged cats ususally do nothing but cause exhaust issues, and occasionally overheating issues....if the cat simply is doing nothing your running like a true rotary without even wanting too...a quick and cheap way to test if its good, though not that healthy is to simply go next to your exhaust with the car idleing....
if you can breath ok and feel alright with only slight nausea then they work...however, if it smells strong of burnt gas and oil, if your eyes start to water up and you quickly feel sick while standing behind your car theres a strong chance your cat has kicked the bucket
if the airpump is acutaly working, if not, and its the stock cat..then odds are the cat is dead...see above test
test your sensors to see if there functioning properly, such as TPS, AFM, MAP, CTS, BAC...specs for each sensor should be in the FSM
bad sensors makes the pcm default to rich to save the engine from detonation
if your lean your a/f you run risk of detonation, nothing better then blowing your engine by just getting your car inspected right?
as for jaison's comment on codes..the odds that that dynosaur of a pcm will actually notice anything enough to pop a code is very slim....and one wire o2's barely do anything as well since it wont get a reading till the engine is 100% warmed up
you could also check your BAC valve to see if your coming out of cold start...if your stuck in cold start you will run rich..which leads to the next thing...if the actual valve is functional then there is a possiblitiy theres a bubble in the coolant which is messing with the CTS
though i have not tested johns alcohol trick....judging by his shiny new inspection sticker i would say it works....you might want to contact him for more indepth explination....im sure doing it wrong wont be very good for your engine..
my last two ideas are kind of cheating
first..your could try that new gas there making for a week..whats it called? E85? the corn crap...i heard all you have to do is run it a bit rich and you will be good
and lastly...be bad.....ill let you figure that one out on your own
Old Jan 20, 2009 | 08:51 PM
Agent-7's Avatar
prodigy racing
hahaha thanks man on all that info, im gonna give my car a new tune up and replace the O2 sensor, and the cat and exhaust are pretty much new, its a complete racing beat exhaust system, so yeah..im gonna get it tested again in a week and hopefully it'll pass.
Old Jan 23, 2009 | 02:49 AM
FeatherTheClutch's Avatar
K9 unit? Beaver unit!
This is what worries me about buying a TII and modding it in CT..
Old Jan 25, 2009 | 09:11 PM
wtgator69's Avatar
I have a cat-less street ported fd and I pass emissions every 2 years by bolting on a cat and plumbing in an electric air pump... you should be able to do the same with an fc... pm me if you want more info
Old Feb 26, 2009 | 04:45 PM
Street Raider's Avatar
Im in the same boat. I want to buy an FC from out of state but all the emission stuff has been removed and it has no cats. Would that alcohol trick work you think? Or does anyone know a "friendly" garage?
Old Mar 4, 2009 | 02:13 AM
Agent-7's Avatar
prodigy racing
actually if you have a racing beat exhaust i bought a custom cat for it, it bolts right up replacing the presilencer, if you need help let me know, i passed my car about a few weeks ago.
ls1swap
Jun 3, 2024 03:25 PM
Snook
Feb 27, 2021 02:54 PM
PinkRacer
43
Oct 1, 2015 09:13 AM
RedBaronII
Sep 20, 2015 11:29 AM
