Cut air pump belt?
Old May 19, 2002 | 06:06 PM
mwpayne's Avatar
Admitted 'rexaholic'
Cut air pump belt?
I wanted to change the worn out alternator belt on the 85, noticed I had to remove the air pump belt first. Went to loosen the air pump bolt, SNAP, the rusted bolt sheared off! Now what? Can I just cut the air pump belt and forget it, or 'bad idea'? I have a straight pipe exhaust with one cat and a muffler.
Opinions? thanks
Old May 19, 2002 | 06:25 PM
Rotarius's Avatar
Im not sure but if you have a six port 13B on your 85 the air pump activates the high speed auxiliary ports to make more power. Check . But you could wire them open. The air pump is for emissions also. ...Rotarius
Old May 19, 2002 | 06:52 PM
mwpayne's Avatar
I'm sure its just the 12A, anyone take off the air pump (specifically, just remove the belt with any side effects?
Old May 19, 2002 | 08:20 PM
peejay's Avatar
Old [Sch|F]ool
The air pump does NOT actuate the 6-port actuators on GSL-SE's, exhaust backpressure does.
Removing the air pump belt with no other changes will result in rapid alternator belt failures as well as possible idle/driveability issues.
Skeese
65
Mar 28, 2017 03:30 PM
c0rpse
Aug 25, 2015 11:50 PM
86glxNA
Aug 22, 2015 08:54 PM
12abridgeport
Aug 17, 2015 06:28 PM
