what is a short crank 20b?
Old Dec 19, 2008 | 10:33 PM
lanceC's Avatar
i was reading about mad mikes p-port 20b and on his website it says it has a custom short crank. what is that?
Old Dec 19, 2008 | 10:49 PM
Evil Aviator's Avatar
Rotorhead
http://www.hitman.hm/engine.htm
Old Dec 20, 2008 | 05:19 AM
bosscobra's Avatar
is that rice i smell?
most people do the short crank when doing a p port if space is tight,
Old Dec 20, 2008 | 11:48 AM
RoTaRyBoYz's Avatar
InsaneRotaries.com
say what?????
Just when you thought you herd it all
Old Dec 20, 2008 | 03:06 PM
GtoRx7's Avatar
Collections Hold
Originally Posted by RoTaRyBoYz
say what?????
I think he is simply saying a short crank kiwi/extreme rotaries 20b setup is only ideal for a full p-port engine. And with it being 1.5 inches shorter its good for tight space applications. Makes sense to me?
Old Dec 20, 2008 | 11:28 PM
RoTaRyBoYz's Avatar
InsaneRotaries.com
^ Thanks, but I find the idea of "most people" that are using this setup because of "tight space" hard to swallow
Somehow I was under the assumption that it has more to do with the design advantages over a standard 20b.. but hey, what do I know
Old Dec 21, 2008 | 09:58 AM
bosscobra's Avatar
thanks gtorx7, bassicly what i was getting at is the fact that a short cranked 20b is more suited for a p port settup because of the intake restrictions running the 13b intermediate plate. the thick 20b plate has a primmary and secondar intake port in it. instead of the 2 primaries of the 13b plate. its less about people using it for the space restrictions. i just threw that out there because that does influence some builders
Old Dec 21, 2008 | 04:43 PM
t-von's Avatar
Rotor Head Extreme
What you just mentioned about restrictions is not a factor because either 3rotor PP will have all the side ports blocked off.
Old Dec 21, 2008 | 09:38 PM
bosscobra's Avatar
the restrictions were directed towards the people using the short crank 3 rotor on a side port motor
sherff
Sep 12, 2015 12:22 PM
Monsterbox
Sep 11, 2015 03:29 PM
meetRoX7e
Sep 11, 2015 11:09 AM
