Swapping 88 N/A FOR 91 TII! is it worth it?
Old May 18, 2002 | 02:21 PM
Thumbs up Swapping 88 N/A FOR 91 TII! is it worth it?
I have and 88 N/A and it smokes when I start it when i hold it at 4,000 RPM's..... A friend is going to sell me his engine, turbo, transmission, drive shaft, ECU, etc... Basically anything that i need that he has on his car. My question is this: Is there anything that i need to pay special attention too before i swap? How can i make the swap legal? If so, how much will it be to make it legal? How long would it normally take to do the swap?.....by the way i have all the tools necessary to do the Job (Uncle is a Certified Mechanic) I also have the haynes rx-7 bible and mazdatrix is just a couple miles away....thanx for the help!
Old May 18, 2002 | 02:25 PM
j a r o d's Avatar
Dont do business with friends or family. if the parts go bad, you will want your money back. then he will sick his robo-dogs on you.
Old May 18, 2002 | 03:25 PM
HE'S ONLY CHARGING ME $600 FOR EVERYTHING AND ANYTHING I WANT FROM THE RX-7 EXCEPT DIFF.. AND BODY PARTS
Old May 20, 2002 | 04:31 PM
j a r o d's Avatar
RAWR!!
Old May 20, 2002 | 04:48 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
You are doing 2 difficult things: Converting an NA to a TII, and swapping between series.
Differences in NA/TII:
Differential
halfshafts
transmission
driveshaft
clutch
pressure plate
flywheel
clutch slave cylinder
starter
ecu
engine wiring harness
dash wiring harness
fuel pump
boost sensor
instrument cluster
other piddly ****
Difference in Series IV and Series V cars:
Engine wiring harness
dash wiring harness
ECU
almost all sensors
AFM
instrument cluster
again, other piddly ****
In short, this is a difficult process (to change from an NA to a TII) even staying within the same "series" and making a hybrid between 2 series only compounds the problem. Hope you have a lot of time, patience, and experience... or $$$$$$$$$ to pay someone to do it.
Brad
Old May 21, 2002 | 02:18 AM
wow...no kidding..........I thought i might be that bad but i had no idea it was like that..............isn't the drive shaft and differential the same though??
immanuel__7
Canadian Forum
Sep 2, 2015 08:26 AM
ncds_fc
Aug 15, 2015 10:06 AM
