sooo i need some help
Old Dec 18, 2008 | 02:49 PM
tonykornkid's Avatar
Newbie
Arrow sooo i need some help
so ive my fc for about two years and its been a total rebuild...and noe im ready to start it! But for some odd reason im not getting any spark at all! and i cant find a ground anywhere maybe some one can help me out?
Old Dec 20, 2008 | 12:46 AM
farberio's Avatar
NASA-MW ST4
The coils should be grounded to through the chassis at their mounting points. Use a test light to ensure the black/yellow wire is getting 12V.
Also check that the engine is indeed grounded.
Old Dec 20, 2008 | 10:07 AM
Aaron Cake's Avatar
Engine, Not Motor
Is the CAS plugged in? Do you have 12V at the coils as mentioned above?
What do you mean when you are looking for a ground? The entire chassis is ground?
http://www.aaroncake.net/rx-7/grounding.htm
ra ra rotory
33
Apr 4, 2003 11:41 AM
Rx7 922
Mar 23, 2003 12:37 AM
ROTORHP
Feb 24, 2003 08:17 AM
Zulu
Jul 30, 2002 04:05 PM
AREITU
Apr 22, 2002 04:20 PM
