Bled--still more air!
Old May 17, 2002 | 11:27 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
Angry Bled--still more air!
A few days ago, I lost clutch pressure and had to pump my *** back home... But it's real weird, because when I let it sit at the bottom of my driveway for a couple of hours, all the pressure came back. So I was thinking maybe too much air and bled the system--I used up almost 2 cans of DOT3 brake fluid... I KEEP getting more air... Somewhere, there is air coming in, but where?!
Busted slave? Master?
Help!
Old May 17, 2002 | 11:29 PM
yayarx7's Avatar
Are you Nucking Futs?
could be a bad seal in the line hose somewhere. or a cracked rubber line. A bad slave cylinder might let air in also.
Old May 17, 2002 | 11:41 PM
FuLLsMoKe's Avatar
The only rubber line is from the metal line to the slave, right? That is not cracked... I'm thinking the slave or master is bad... Not sure how to tell which is bad...
Old May 18, 2002 | 12:14 AM
yayarx7's Avatar
should be the slave, it is a good idea to replace both at the same time. Unless you are broke, go replacment, if broke, rebuild. Be aware, you will probably do it again in a year if you rebuild.
Old May 18, 2002 | 12:52 AM
FuLLsMoKe's Avatar
ok, i think i'll fork out some cash to just go ahead and replace both--any tips or what to watch out for?
Old May 18, 2002 | 06:36 AM
DONNA's Avatar
mine lost pressure at times too, was a pin hole in the rubber hose, also rebuit the slave, cost 20 bucks total, dont recall putting in that much fluid thou. carefully hone out the slave innards,,,good luck
Old May 18, 2002 | 08:08 AM
peejay's Avatar
Old [Sch|F]ool
Master cylinder is failing. They fail intermittently at first, and gradually get worse until you're on the Full Mayday Program.
The "still has air in it" is another clue. It's sucking air through the rear seal.
For final confirmation, look under the dash at the back of the clutch master cylinder. I bet you there is a big ol' stain of brake fluid drooling down the firewall.
Old May 18, 2002 | 06:05 PM
FuLLsMoKe's Avatar
No fluid from the inside of the car... I may just replace both the master and slave soon--but I gotta order parts...
FlatVermin
22
Sep 27, 2015 05:42 AM
