Megasquirt Been doing some reading
Old Dec 13, 2008 | 07:33 PM
Righty's Avatar
Very Hatefull.
ON Been doing some reading
I've been looking to put in an EMS and have a few questions.
What do I need?
Ill be going:
v3 board
MS2 chipset
4 bar map
wiring harness
little resistors and such that a wankel needs
What else?
I want to control Ignition, fuel injection, WBo2 and some other stuff like my efan...
I wont be running stock ignition, whats my best bet? (ls1/ls2 coils look expensive..)
I want to clean the **** out of my engine bay. What sensors do I need?
Just those? Is it better to add on stuff like knock sensor? Stim board? etc?
I was also thinking about running 2 o2 sensors, here's my logic.
normally the o2 sensor helps determine how much fuel to put in.
if housing 1 is running rich, and housing 2 is running lean they will balance out because there's only 1 o2 sensor. That doesn't seem to optimal. So if i had 2x o2 sensors, it would correct for each combustion chamber, and boht would have proper AFR(whatever that is set to)
SO:
What gains/hassles would come with an additional WB 02 sensor, and is it worth the extra coin?
I've been going through the mega manual and trying to digest as much as possible. Whats the best way to run 4 injectors? does the standard MS2v3 control individual port injection? Will it run my ignition as its suposed to? ie lead, then trail?
thanks in advance.
Old Dec 14, 2008 | 10:28 AM
Aaron Cake's Avatar
Engine, Not Motor
What do I need?
Ill be going:
v3 board
MS2 chipset
4 bar map
wiring harness
What else?
You'll need to build the 2nd VR circuit on the proto area in order to run the stock CAS. It's best to use high quality shielded 4 conductor microphone cable for the CAS pickup so you'll need to add that to the harness that the Megasquirt vendors supply. It has only one VR wire by default and it's poorly shielded.
I suggest configuring your 'Squirt as the following:
Use one IAC wire for you e-fan.
Use the remaining three as ignition outputs.
Set it up to control the BAC by modding the board, using the FIDLE output.
Use two of the spare pins for the 2nd trigger wheel.
You can use the 2nd gen ignition and it's probably the best configuration. It's really hard to beat the 2nd gen ignition system.
You need a TPS (full range is best), IAT, CLT and O2. For the IAT and CLT I recommend going with the GM sensors. It's slightly easier then using the stock sensors since you don't have to reprogram the 'Squirt and replacements are available at any auto parts store. Also the connectors are new and Weatherpack.
Knock sensing isn't going to help you avoid detonation, so don't bother.
The Stimulator is only used when bench testing the 'Squirt.
Run a single wideband and use a dual EGT setup. It will provide far more valuable information.
Have you read the large Megasquirt FAQ at the top of this forum?
You'll use INJ1 to run your primaries, and INJ2 to run your secondaries. The Megasquirt batch fires injectors.
Old Dec 14, 2008 | 10:52 PM
Righty's Avatar
Very Hatefull.
I read the main FAQ I thought, I'll double check. It was smaller than then main MS FAQ's on megamanual.
Each night I try and skim over the megamanual, and re-read things I don't fully understand.
Thanks for the input. Might sound weird but I look forward to meeting you.
Old Dec 16, 2008 | 08:53 AM
Aaron Cake's Avatar
Engine, Not Motor
The 'Squirt has a steep learning curve, especially if you don't have any electronics experience. But on the plus side, Megasquirt people are probably among the most helpful out there.
squirrels
Sep 1, 2024 09:52 AM
eplusz
15
Oct 7, 2015 04:04 PM
Devon Murray
Sep 25, 2015 09:41 AM
subeone
Sep 24, 2015 09:58 PM
befarrer
Sep 22, 2015 09:33 AM
