I'm buying a TII 13B, is this a well known company?
Old Dec 7, 2008 | 08:58 PM
Snaple07's Avatar
SD I'm buying a TII 13B, is this a well known company?
the company is called:
http://www.diamondjapanese.ca/index.php
I was wondering if I should go with company or not
please give me some facts/opinions or views on buying a used 13BT
Information on the engine (this is what the company says)
13B TURBO ENGINE ONLY MAZDA RX7 88-89
Mazda
Item: # 2092
$850.00
Description: Make: Mazda/ Model: RX7/Year:88-91/ Engine code:13B/Horse Power:205hp @ 6500/Torque :193 lbs@ 3500/ Mileage: Approx 30-40 Thousand/ Condition: Best/ THIS ENGINE IS FOR MAZDA RX7 88-91.... INCLUDED: COMPLETE MOTOR, COMPLETE HEAD, INTAKE MANIFOLD, EXHAUST MANIFOLD, TURBO,ALTERNATOR,POWER STEERING PUMP, FUEL RAIL, INJECTOR, THROTTLE BODY AND SENSOR AS PICTURED
Attached Thumbnails I'm buying a TII 13B, is this a well known company?-diamond-002-13bt.jpg
Old Dec 8, 2008 | 09:38 AM
Aaron Cake's Avatar
Engine, Not Motor
I've never heard of them.
But keep in mind that J-spec engines are essentially junkyard engines. They are hit and miss, and the importer has no real way of knowing how much mileage is actually on the engine.
Old Dec 8, 2008 | 01:05 PM
Snaple07's Avatar
thanks, that brought me back to reality. I've been so excited about buying an engine that I total forgot about what I'm getting into.
So basically, even if the engine is good/bad I should rebuild it (seems like a no-brainer but I'm an amateur at the wankel engine). Nevertheless I still plan on working with the engine even if its not running.
Old Dec 8, 2008 | 01:09 PM
Aaron Cake's Avatar
Engine, Not Motor
Some people will jump in and say you should immediately rebuild any J-spec, but I really don't agree. If the engine is in good shape when you get it and shows good compression, then there should not be any issues with just using it as is. If you plan to make 400HP, certainly rebuild it since you'll want to street port it anyway. But if it's just a stock replacement or for a TII swap then a rebuild is unnecessary if it's in good condition.
Snaple07's Avatar
many of these J-spec engines are city driven, so I don't expect a high life expectancy. Not only that, the previous owners of the car may not have been a good driver or even a good maintenance person.
Old Dec 26, 2008 | 12:34 PM
deliverator's Avatar
It looks like their web site was only registered in late June of 2008.
No web site history available via the Wayback Machine, nor any informative hits in google.
Might be wise to go with a more established company.
Old Dec 26, 2008 | 12:44 PM
Did some more searching.
If it's the same company, they don't seem well liked...
http://www.locostusa.com/forums/view...c023f1eaccbf88
Old Dec 26, 2008 | 03:51 PM
old_skool's Avatar
you know you want this
i'll have to disagree with you on this one. looked up his feedback on eBay, in the past 12 months, 3 negative, 80 positive. doesn't sound to bad...
Old Dec 26, 2008 | 04:32 PM
MattG's Avatar
MattG FTW!!!!!
Try it, I got a j-spec engine TII its got over a 100 PSI in each rotor.
Old Dec 26, 2008 | 06:16 PM
RotaryRocket88's Avatar
Top Down, Boost Up
If they have a warranty in writing, then it's worth the try. I bought a S4 motor & transmission for $1200 from gotjdm.com, which is somewhat local for me (Indio, CA). They actually buy from Osaka Japanese, which has a so-so reputation, but the sales guy w/ gotjdm was pretty decent and even replaced the transmission after UPS broke the first one in shipment. Having a middle-man ended up working in my favor.
Just make sure you get a receipt of some kind sent to you in case the motor you get is blown. The motor I got was extremely clean internally and had 115/120 compression, which is amazing, and both transmissions shift well too.
So you can luck out and not need to rebuild. But there are blown engines out there being sold by people who have no idea how to test compression, so cover your bases before you commit.
Old Dec 27, 2008 | 02:05 PM
Snaple07's Avatar
The website does have a warranty
http://www.diamondjapanese.ca/warrenty.php
Th0m4s
Feb 26, 2019 02:04 AM
Ciclovnz
Oct 18, 2015 03:04 PM
plentymoon
NW RX-7 Forum
Sep 5, 2015 08:55 AM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
