What is this part under the UIM
Old May 16, 2002 | 09:32 PM
c00lduke's Avatar
I was wondering what this part is and what would happen if this came off? Also, i think it might be the AWS and in that case if i remove it will i need a block off plate?
Thanks
~Luke
Old May 16, 2002 | 09:34 PM
c00lduke's Avatar
sorry,
Old May 16, 2002 | 10:04 PM
Brad's Avatar
dear baby jesus...
Yeah, it is the AWS. Get rid of that freaking thing man! Yes, you will need a block off plate.
Old May 16, 2002 | 10:06 PM
c00lduke's Avatar
what would happen if i dont, and would i just put a cap over the part in the intake elbow?
Old May 16, 2002 | 10:13 PM
amp's Avatar
amp
old yella
AWS
If you remove it...youll need 2 block off plates and a cap for the elbow.
You can easily create block off plates with .125" aluminum stock.
Old May 17, 2002 | 02:13 AM
7-sins's Avatar
thats not paint....
What does that do for the motor? emissions?
Old May 17, 2002 | 03:19 AM
silvr94r2's Avatar
I took mine off completely......looks very very nice I'll post the finished pics when they are......uh finished
Old May 17, 2002 | 07:35 AM
amp's Avatar
amp
old yella
7sins
AWS Accelerated Warmup System for o2 and precat...it runs your revs high upon startup for quick warmup..yes emissions
imho not good on cold starts.. removal is one way of avoiding it but a bypass is as easy as blipping your throttle upon start or start it in gear.
Old May 17, 2002 | 08:27 AM
puma's Avatar
canadian monster
i don't think you need two block of plate. If you look closly how it's done, onlu one will be necessary if it covers both hole.
Only the one on the solenoid is needed since the pipe takes the air by the solenoid.
puma
Old May 17, 2002 | 11:36 AM
7-sins's Avatar
thats not paint....
Originally posted by amp
7sins
Thanks man, I have the PFC so that thing is just wasting space.... net time I have my UIM off.
Old May 18, 2002 | 08:03 AM
93FD3S's Avatar
Big Snail
Don't u need resistor....?
I have tried to remove the AWS, actually just pluged the hole on the AWS and on the elbow with rubber stoppers, I also unplugged the electrical connector. Well when I went to start the car Which was fully cold, the car would start and die right away. Tried to restart but won't start. So I plugged the electrical connector back in and still won't start. Went ahead and reconnected AWS by removing rubber stoppers and reconnecting harness and car starts right up. So I'm thinking the ECU is looking for a feedback signal, which leads me to think u need a resistor.....? Any input would be great....Thanks...Tony
Old May 18, 2002 | 02:07 PM
turbojeff's Avatar
Do it right, do it once
Re: Don't u need resistor....?
I took off my AWS system and didn't have any problems, no resistor required. At the time I had my plates made I had 20 more sets made to make it cheaper for me (no one was selling them at the time). I sold all 20 sets and never had anyone tell me that they had problems either. My car has been this way for ~1.5 yrs.
Jeff
Thomas618
Aug 21, 2015 09:21 AM
elfking
Aug 19, 2015 09:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
