Oil Metering Pump block of plate???
Old May 16, 2002 | 07:18 PM
to_slow's Avatar
If I install the Oil Metering Pump block of plate what will happen ?What does the metering pump do and what is the full procedure how to do it right ?
Thanks
Dan
Old May 16, 2002 | 09:37 PM
Brad's Avatar
dear baby jesus...
The Oil Metering Pump injects a small amount of oil into the combustion chamber to keep the seals lubed and sealed properly. If you remove the pump and block it off, obviously you will no longer be injecting oil into the combustion chamber.
People normally remove the OMP when going Haltech, because it doesnt control the OMP. Downside (I think it's a plus) is you have to run premix now. You can purchase premix from places like Pettit, but it's essentially two-stroke oil. Alot of people use jet-ski oil.
I think that route is better anyway, cause premix lubes and seals better than regular dino or synthetic oil.
As far as the full procedure...we'll it's not that easy. The pump is located kinda under the thermostat housing on the turbos side. It has two thin tubes coming out the top...one going to each rotor housing. These will also need to be removed, and their nipples capped (glued and zip-tied would be best). There are three bolts holding the pump on, and they aren't very easy to get to. A shop manual is a must on this one...and I wouldn't recommend doing it unless you are VERY comfortable working on your own car.
Old May 17, 2002 | 06:09 AM
to_slow's Avatar
Thank .. You !!! Is it a good idea to take the oil injectors out and plug the hole with some bolts ? And if any one has done this (plug the holes up with bolts)can you tell me what size it was and where did you get them
Thanks
Dan
Old May 17, 2002 | 07:12 AM
ErnieT's Avatar
Living life 9 seconds at a time
I kept the actual pump in place, but blocked off the oil lines going out of it and on the block. Works well. Just make sure you run pre-mix.
Old May 17, 2002 | 08:13 AM
airborne's Avatar
King of the Duct Tape
I was reading the manual and it places the OMP as a cause for starting problems (which i'm having). How could it cause these problems? Too much oil into the engine or what? Electrical issues?
Enlightenment requested!
Old May 17, 2002 | 01:21 PM
Brad's Avatar
dear baby jesus...
I dont think it would be necessary to remove the actual oil injectors. More of a hassle really. Just cap the nipples.
As far as the OMP causing starting problems...the only possible scenario I could think of is injecting too much oil. Oil obviously doesn't combust like gasoline, and too much oil would inhibit the gasoline from burning properly. Try just disconnecting the electrical connection to the OMP...add a little two-stroke oil to the gas tank...go from there, see if it solves or helps your starting issues.
Th0m4s
Feb 26, 2019 02:04 AM
Snoopy FD
Dec 8, 2015 01:45 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
