Megasquirt rx8 mode?
Old Nov 26, 2008 | 09:52 PM
chango de naranjito's Avatar
rx8 mode?
Anyone have info on that? there is nothing in the manuals.I search the forums and I see is maybe a way to run 4 coils in cop way...but not find any info or anyone using it
Old Nov 28, 2008 | 07:29 PM
-xlr8planet-'s Avatar
I has an emblem
no te sigo realmente...
Old Nov 30, 2008 | 05:21 AM
Viich's Avatar
Migrant Rotorhead
I think Rotarygod was running tests with an RX-8 with a Megasquirt and the stock ECU running in parallel last year or the year before.
Old Nov 30, 2008 | 05:29 AM
in the msn2 extra rotary split table setings says rx8 mode enable or disable what that means? and how is wired? Gracias
Old Nov 30, 2008 | 05:31 AM
ahhh, so no 4 coils big boom?
Old Nov 30, 2008 | 07:51 AM
pmrobert's Avatar
msextra.com
Old Dec 1, 2008 | 09:22 PM
Originally Posted by pmrobert
msextra.com
please tell me if you find any info in that site I do not find any
Old Dec 2, 2008 | 09:24 AM
muythaibxr's Avatar
MegaSquirt Mod
I've posted info about it on msextra and here.
rx8 mode allows you to run 4 coils. You have to turn on FD mode to get the COP trailing to work, then turn on rx8 mode to get COP leading to work.
Looking at the front of the MS:
Left LED: front leading
Right LED: front trailing
Middle LED: rear trailing
JS11: rear leading
For JS11, you should build a circuit that looks like the other three LED circuits to drive the 4th coil, assuming you're using rx8 coils.
Ken
Old Dec 2, 2008 | 07:44 PM
JS11: rear leading
Ken
thanks!!!!!!!
Old Dec 2, 2008 | 11:45 PM
rotarygod's Avatar
Rotors still spinning
I made it run on fuel only control but that was before it was able to control ignition. Now you can just reprogram the factory ecu so we abandoned that project. However if anyone ever installs a Renesis into another car, it would be worth doing.
Old Dec 3, 2008 | 02:38 PM
Viich's Avatar
Migrant Rotorhead
NB
<--- my eventual plan.
Not ambitious enough to try to do everything at once though. I want to get the MS running on my 12A first, then maybe some suspension and steering stuff, and then deal with the Renesis. Or 16X if it's around by then.
Old Dec 3, 2008 | 03:16 PM
toplessFC3Sman's Avatar
well, the 16x is direct injected, which is something megasquirt doesnt support (at least not yet)
24seven_dada
20
Nov 10, 2018 12:03 PM
gfd263
Megasquirt Forum
Aug 28, 2016 08:58 PM
