Haltech block-off plate question
Old May 15, 2002 | 03:35 PM
Just purchased block-off plates for my 89 Jspec turbo motor so I can disengage the electronic oil metering pump. Now as far as the holes where the oil injectors sit, how do I go about blocking those off? I was thinking duct-tape but that might not be a good idea otherwise, just a metric bolt might do the trick... Any suggestions from the Haltech guru's??? Thanks for your help. Mort
Old May 16, 2002 | 08:17 AM
tims's Avatar
bolt with a new crush washer is all that is needed.
Old May 16, 2002 | 12:06 PM
thanks thats all I wanted to know
Old May 17, 2002 | 03:55 PM
matt122's Avatar
Where did you get the Metering pump block-off plate? I'd like t get my hands on one.
Matt
Old Jul 25, 2002 | 08:10 PM
mikeric's Avatar
FB=OS Giken LSD
I was told that I should leave that in place as the engine will suck in a little oil.
I was also told (by rotary/Haltech tuners), that with every tank of gas, I need to add 6-10 ounces of two cycle engine oil to my gas tank as a premix. Is this right?
Old Jul 29, 2002 | 05:51 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Matt
All it takes is a sheet of 1/4" aluminum plate and start cutting
The OMP nozzle holes can be plugged with a short metric bolt. I forget the patter, but I THINK its 12mmX1.25mm , get is about 1/2" long...
Old Aug 18, 2002 | 10:07 AM
Kurgan's Avatar
Gaijin Racing
the oil injectors are 10m bolts
Old Aug 21, 2002 | 03:04 AM
Greg's Avatar
or www.k2rd.com
Old Aug 22, 2002 | 06:29 PM
MIKE-P-28's Avatar
On my cosmo engine it wasnt, they were 12mm X 1.25mm , fits a 14mm socket
83revival
Sep 3, 2015 10:42 PM
