what would my 1/4 times be with a slipping clutch.
Old May 15, 2002 | 12:06 PM
Zoomspeed's Avatar
My clutch my be slipping, I'm not sure yet. (I'll probably hcange it anyway just so I'm not paranoid.)
I'll be going out to the track this friday, what do u guys think my times will be if my clutch is slipping and I have som OK tires?
my mods are in my sig.
Oh, and assume I'm not a good driver.
Old May 15, 2002 | 12:28 PM
Dragueur's Avatar
dont know....
u got MORE modS than me...im STOCK with a slippin STOCK clutch.....i ran a 14.0 at 101 mph.....
Old May 15, 2002 | 12:35 PM
airborne's Avatar
King of the Duct Tape
time in sig...i think my mods at this time were pettit intake, dp, hiflo cat, catback, PFC, streetport, flywheel, slipping act clutch.
also it was like 100degrees out that day.
Old May 15, 2002 | 01:36 PM
GsrSol's Avatar
Z06 powered FD
Depends on how bad it is slipping. I would say the car is capable of a real high 12 without it slipping.
Old May 15, 2002 | 02:57 PM
turbojeff's Avatar
Do it right, do it once
A slipping clutch can explode, bad idea to race it IMHO.
A stock clutch and a lot of mods are what got JimLab started on workin' on his FD with 4K miles.
The problem is when you have a clutch that slips "just a little" with mods is that it actually still has a decent amount of clamping force. That means it'll produce a lot of heat when it slips. That heat can cause stuff to fail. If the clutch fails when your running WOT the rev limiter won't do any good...
Jeff
Old May 15, 2002 | 03:28 PM
Zoomspeed's Avatar
Re: what would my 1/4 times be with a slipping clutch.
[i]Oh, and assume I'm not a good driver. [/B]
don't forget this part guys.
Old May 15, 2002 | 03:41 PM
WhiteRXseven's Avatar
IMO..
WHY even bother doing WOT 1/4 runs with a
slipping clutch?? Bad idea..
Not only is it bad for the car. There is no way
to get good/accurate #'s...
Ask yourself. Is it even worth it???
I can see all the RIKKI's licking their chops
waiting to pounce on your FD3S, after them
watching you run 15's 16's 17's. Hahaha.
Gonna give FD3S a bad name.. People watching
wont know you have a bad clutch.
If I was you.. I would wait, replace yoru clutch
then go have fun..
Old May 15, 2002 | 08:36 PM
noon's Avatar
Obsessed
Azn are you talkinga bout the HS drags? I'm going to that with the same guy that was with me today(just to watch) IM me and I'll give you my phone #
Old Jul 2, 2002 | 02:48 AM
30psiBoost's Avatar
how do you determine oif your clutch is slipping? with my stang i was told to put it in 5th at 30 and floor it. it wont accelerate if its slipping being it is under alot of stress. Is there a diff way for FD's
Old Jul 2, 2002 | 05:12 AM
amp's Avatar
amp
old yella
if your car is not accelerating relative to your revs
Old Jul 2, 2002 | 05:25 AM
laujesse's Avatar
Thrashing your Roy score!
Veteran: Air Force
In addition to what that guy was saying about messing the clutch up worse... You can over rev your if it is sliping bad and as you said "assuming you are a bad driver". Dont take it out if the clutch is bad, nothing good can come of it including your 1/4 mile time. Jesse
Tylerx7fb
39
May 27, 2019 12:45 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
rx7jocke
Aug 15, 2015 03:36 PM
