rx3 carbs same as rx7
Old May 14, 2002 | 10:53 PM
minocqa's Avatar
hi
are the rx3 carbs the same as the ones on the rx7
a guy on ebay had one , he said that it came off his 13b
until he swithced carb's
just wondering what you guys would have to say about it.
thanks
Old May 14, 2002 | 10:58 PM
yayarx7's Avatar
Are you Nucking Futs?
if it was from the factory on a 13b it is a hatachi, the 12a carbs are nikkis, if you need a extra or better carb go to the junkyard and get a nikki, then rebuild, or send it to Paul Yaw and for $300 he'll make it THE best carb for a street rotary,(witch, by the way, is less than Rx7.com charges for a rebuild and r&r).
Old May 14, 2002 | 11:10 PM
RotorMotorDriver's Avatar
Seven Is Coming
Hmmm...I have a spare working Nikki (for sale?) and about $300, does that Yaw carb run good for a stock port? You said "street rotary", did you mean SP, or just a street application?
~T.J.
Old May 14, 2002 | 11:14 PM
yayarx7's Avatar
A street application, or a race application that requires you to use the nikki.
link:
http://personal.riverusers.com/~yawpower/
Old May 15, 2002 | 03:06 PM
minocqa's Avatar
thanks for the response. how much do you want for the nikki? .....TJ
Old May 15, 2002 | 03:49 PM
Siraniko's Avatar
RX for fun
how much do you want for the old rx-3 carb. i like them better than the nikki's.
Old May 15, 2002 | 10:40 PM
repuguru's Avatar
They are Nikkis. The 13B goth Hitachis.
Old May 16, 2002 | 01:17 PM
hanman's Avatar
Not to scare anyone off a Yaw carb, but $300 will not cover it. Plan on around $500.
You need to replace the fuel pump, add a regulator, and buy a pressure gauge. Along with the carb pricing, which is slightly more than an even $300, and you are going to beat the hell out of a $500 bill.
It's worth it, but just be aware of all of the costs.
just my opinion,
hanman
Old May 17, 2002 | 03:05 AM
alien_rx7's Avatar
Interstate Chop Shop CEO
RX-2 carb
What about the RX-2 carb off of the twin dizzy 12a? Is it the same as what is on our 1st gen 7's?
Old May 19, 2002 | 11:42 AM
repuguru's Avatar
It is an early version of that carb. But the 7 Nikki is more refined.
Old May 19, 2002 | 02:15 PM
peejay's Avatar
Old [Sch|F]ool
I wouldn't say that is part of the price of the carb. After all even a STOCK engine/carburetor kinda needs the new fuel pump and accomanying regulator and gauge. Put a header on the car and you definitely need it.
Th0m4s
Feb 26, 2019 02:04 AM
thecody59
40
Aug 23, 2015 06:41 PM
