How Important is the ABS Heat Shield?
Old May 14, 2002 | 10:23 PM
c00lduke's Avatar
How important is the ABS heat shield if i still have the stock DP. Other words how hard should i look to find it in my garage? Just wondering cause i havn;t driven my 7 in about a month and i'm get anxious(sp?)
Thanks
~Luke
Old May 14, 2002 | 10:35 PM
P'cola FD's Avatar
Hamado things my way!
Put it on there. Not a good idea to mess with the system that could one day save your life.
Old May 14, 2002 | 10:36 PM
Import Convert's Avatar
Mazda went through a lot of trouble to save weight on the RX-7. If they put it there, it's probably important.
Old May 14, 2002 | 11:57 PM
GsrSol's Avatar
Z06 powered FD
It's pretty important, the heat can find its way around the shield but atleast it won't be direct heat hitting the lines and the unit. It will heat up your brake fluid.
Old May 15, 2002 | 07:43 AM
wasabi's Avatar
The ABS hydraulic unit is one the most expensive single pieces to replace on the car. Put the heat shield on...
-MP
Old May 15, 2002 | 09:19 AM
jmo87's Avatar
i took mine off when I put on my downpipe and completely forgot to put it back on until I stumbled upon it a couple months later in the garage. It's back on.
Old May 16, 2002 | 12:34 AM
c00lduke's Avatar
Ok i found it and now it is back on, no worries
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
RuffRx7
Oct 1, 2015 03:08 AM
