Power FC Help with Power FC
Old Oct 31, 2008 | 10:19 AM
chemicool's Avatar
Help with Power FC
Anyone have any MAPs for a FD with Large Street port? Also, looking for Stock FD MAP if anyone has one for comparison.
Another question. I have tried to copy and paste from Excel into Datalogit and when I do it fills all 20x 20 with 1.49 instead of my intended correction values?
Old Oct 31, 2008 | 11:10 AM
arghx's Avatar
rotorhead
chuck actually has all those maps on his yahoo group
Old Oct 31, 2008 | 01:05 PM
chemicool's Avatar
What Yahoo group? How do I get to it.?
Old Oct 31, 2008 | 03:34 PM
twisted7's Avatar
Jake
pretty sure you need to buy his notes to be invited.
Old Oct 31, 2008 | 03:55 PM
chemicool's Avatar
So how do I buy his notes? What is his username here?
Old Oct 31, 2008 | 06:43 PM
arghx's Avatar
rotorhead
pm cewrx7r1 , you pay for the notes and you get access to the yahoo group which has its own forum and notes
Old Oct 31, 2008 | 09:10 PM
thewird's Avatar
Your pasting in the wrong place. The correction map is just that, a correction. 1.49 might be the limit of how much you can correct. Your fuel map is actually the Base map and your correction should all be 1's when your copying a map from excel.
thewird
Old Nov 1, 2008 | 08:21 AM
chemicool's Avatar
So I can only paste into the base map? Not the other MAPS? All I am trying to do is insert some leaner corrections in the INJ map but there a quite a few so I was gonna just paste. I guess I have to do it one at a time?
Old Nov 1, 2008 | 02:34 PM
thewird's Avatar
No, your not getting it. You can't correct more then 49% which is why it defaults to 1.49
thewird
Old Nov 1, 2008 | 03:25 PM
chemicool's Avatar
I'm not trying to correct more than 49%. For instance I am trying to change a 1.21 correction to 1.16. However, when I cut and paste these values from Excel into the inj map it defaults to 1.49. However, if I copy from Datalogit into Excel and then back into datalogit without making changes to the info I copied it will accept it as it is written. It is as though Datalogit doesn't recognize the numbers generated by Excel
Old Nov 1, 2008 | 03:38 PM
thewird's Avatar
You need to select all all cells before pasting.
thewird
Old Nov 1, 2008 | 06:55 PM
chemicool's Avatar
Aw man I figured it out. I'm a dumbass. I was trying to paste numbers from another website and they were listed without the decimal point. So 121 instead of 1.21. So wird you were correct I was , in effect trying to increase the correction more than 49% like you said. Thanks for helping me sort it out
rgordon1979
40
Mar 15, 2022 12:04 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
