help please car idles at 5000 rpms
Old May 14, 2002 | 07:17 PM
streetdreamzny's Avatar
i recently took off my intake manifold(1st time) to get it polished + installed the greddy elbow and intercooler pipes. when i started my car it makes horrible noises and idles a 5 grand . i think i hooked up all the hoses right except the top left of the manifold where the hose from the bov connect, theres two nipples one for the bov and the other i cant find any hose to connect there and dont remeber if anything was there when i took it apart. also i didn't weld a nipple on the greddy elbow just put on a cap on the end that comes from the manifold . also i'm not sure if i put the throtle cable on correctly but dont know if this would rev the car to 5000. sorry for the long post - thanks
Old May 15, 2002 | 10:26 AM
ok,i found the missing hose on top of the manifold - it was the boost gauge vacuum hose, now the car idles at 3000 rpms and still makes a horrible high pitch noise. would switched electrical connectors under the manifold do this ?? thanks
Old May 15, 2002 | 10:42 AM
ejmack1's Avatar
Lawn Ornament
hmmm, make sure the throttle cable is not the cause, also there is a adjustment screw on the front of the throttle body, lossen that all the way and see if you still get this....
Old May 16, 2002 | 06:53 AM
is the throttle cable supposed to have a some play to move both ways or is it supposed to be tight
Old May 16, 2002 | 07:48 AM
ejmack1's Avatar
Lawn Ornament
no play, but not that tight
Old May 16, 2002 | 01:06 PM
it could be your throttle position sensor. try this http://www.scuderiaciriani.com/rx7/TPS_adjustment.html
also make sure no part of the throttle mechanism is getting caught on something, like a hose or tie wrap.
Kyo
Apr 13, 2019 09:24 AM
bb6guy
Old School and Other Rotary
Oct 1, 2018 08:07 AM
Microtech
Aug 23, 2015 11:04 AM
rkhanso
Aug 13, 2015 11:40 AM
bb6guy
Aug 12, 2015 03:29 PM
