Newbie: What Is A Solenoid?
Old May 14, 2002 | 06:43 PM
oneflytrini's Avatar
Stabbed by a pen
Question Newbie: What Is A Solenoid?
ok, i am a newbie, and did a search but didnt find anything but people saying its broke or something else. Can someonle please tell me what the hell a solenoid is and what it does. please reply. thanx
Old May 14, 2002 | 07:32 PM
HEVNSNT's Avatar
Solenoids can be found in electro/mechanical relays and valves. The basic function of a solenoid is that by using a magnetic field you can pull or draw the contacts of a relay closed or pull the spool of a valve open or close.
A solenoid is basically a long wire wrapped around a core. When voltage is applied to this wire it creates a magnetic field.
The term solenoids on an FD is referring to the "solenoid valves".
Old May 14, 2002 | 08:55 PM
JONSKI's Avatar
5yr member, joined 2001
So a speaker is like a solenoid, right?
Old May 15, 2002 | 12:37 AM
ziftar's Avatar
Rotor Head
This might also help to illustrate how a Solenoid functions.
http://www.detroitcoil.com/whatis.htm
Old May 15, 2002 | 12:43 AM
P'cola FD's Avatar
Hamado things my way!
The solenoids people talk about the most on this forum are the solenoids that control the twin turbo system. There is a rack underneath the intake manifold that holds most of the solenoids that run the turbo control sytem. The solenoids are connected by a plethora of vacuum hoses that get old, get brittle, and cause problems. Many times, a bad or broken solenoid results in low boost, that is why you hear so much about them.
Old May 24, 2002 | 03:07 AM
Piston Pete's Avatar
What's the procedfure to test one of our solenoids?
Thanks
Old May 24, 2002 | 08:32 AM
technonovice's Avatar
Jinx
Good FD solenoid testing info:
http://www.wvinter.net/~flanham/wlan...rbo/turbo.html
More food FD TCS stuff:
http://www.rx-7tt.freeservers.com/Tu...leshooting.htm
Bauer778
Nov 4, 2015 04:42 PM
alexdimen
20
Oct 23, 2015 01:50 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
