oxygen sensor
Old May 14, 2002 | 05:33 PM
fLyiNgOuFeR's Avatar
how long did u drive around for? it takes a while for that thing to heat up and start working. try hopping on the freeway or sumthing. my friend had the same problem and he kept fukin with it (ie tapping wires, finding new grounds) and then he gave up and just left it alone. then he said he was cruising around and all of a sudden it started working. hope this helped.
Old May 14, 2002 | 05:45 PM
NZConvertible's Avatar
I'm a boost creep...
Chris, where are you connecting the A/F gauge’s signal wire? At the O2 sensor or the ECU? The cable in the engine bay is shielded and tapping into it can cause problems if you short the shield to the wire. It should be connected at the ECU to avoid this problem.
BTW, the O2 sensor should get to operating temp after about 5 minutes of driving.
Old May 15, 2002 | 05:19 AM
HAILERS's Avatar
HAILERS
2D on a 86-88.
Old May 15, 2002 | 05:44 AM
The Ace's Avatar
Greek Power
The signal wire in the engine bay is shielded ? Never knew that...actually my wire in the engine bay is halfway exposed already (dont know why), and in a very tight spot (so I cannt do anything with it until I remove a bunch of things). You think maybe it is killing my readings on the O2 sensor ?
Old May 15, 2002 | 05:57 AM
HAILERS's Avatar
HAILERS
NZ is saying that there might have been the possibility that someone , if making the connection in the engine bay, would accidently let one of the strands of the grounded shield, touch the center conductor when doing his splice job. The o2 wire when new, was a grey shielded wire. Its probably a brown or tan shielded wire now after all these years. The shield is terminated approx six to eight inches prior to pin 2D at the ECU. From where the shield is terminated, the center conductor continues that last six to eight inches to the ECU. A shielded wire is a wire with a metal braid around the center conductor. The metal braid is grounded. Prevents EMI from interfering with the low voltage output of the 02 sensor.
Old May 15, 2002 | 06:09 AM
The Ace's Avatar
Greek Power
Yeah I knew that Just wanted to check. My mechanic says that the ECU doesnt throw any errors at all, and the O2 is working like a charm anyway, so.....
I do need new plugs though.....there go 120 Euros
Old May 15, 2002 | 03:40 PM
Originally posted by chris-reed
does you o2 have to be connected to the engine?
If it's not, the ECU won't go into closed-loop during cruise and light throttle, meaning fuel economy will suffer.
Old May 16, 2002 | 02:50 AM
The Ace's Avatar
Greek Power
Ace or somebody please help me out here!
Oh yeah, I was wondering what the "other question" was...
Anyway, the A/F meter *should* work like this:
a) when cruising, the LEDs should light up and down constantly, as the ECU tries to compensate and adjusts the A/F mixture some 15-20 times per second (I dont know the exact sampling rate of the ECU. maybe someone can help)
b) when WOT, 8 out of the 10 LEDs (or 80% of whatever measuring scale your A/F meter has) should light up. That means that the ECU is locked into "closed-loop", and disregards the readings from the sensor. The mixture is now always rich (or at least the ECU tries to make it rich ), to prevent detonation.
c) when decelerating, there should be almost no LEDs lit. The ECU is now making the mixture very poor, because the engine is not making any power, so fuel is not actually required to prevent detonation or make power.
What exactly do you mean "comes on" ? How many LEDs does your AF have, and how many light up under different circumstances ?
Old May 16, 2002 | 02:55 AM
RETed's Avatar
ok, cruise and light throttle, I got the guage to work simply by plugging in the o2 sensor wire to the guage wire, it's not connected to the ecu, but during cruise and light throttle the guage does not show anything, no l.e.d.s at all. but when you mash the gas or let off it "comes on" WTF
Autometer 20-LED gauge?&nbsp How high does it go up when you go WOT?
-Ted
Old May 16, 2002 | 02:59 AM
RETed's Avatar
At cruise, how much throttle are you giving it (estimate)?&nbsp What RPM?
-Ted
Old May 16, 2002 | 03:05 AM
The Ace's Avatar
Greek Power
Either the car is running on the poor side all the time, the sensor or the signal are not what they should be, or the A/F meter needs adjusting for your car. These are the possibilities....I say you should use a digital voltmeter and check the O2 sensor and the signal, and then take it from there....
Old May 16, 2002 | 03:14 AM
RETed's Avatar
Do you get any lights at idle?
-Ted
Old May 16, 2002 | 03:20 AM
The Ace's Avatar
Greek Power
The o2 sensor is a 17 dollar discount auto parts piece? could this be the problem?
Cannt tell, because all I can get here in Greece are the Mazda one and the Bosch. But since you already have made the connection, testing the outcoming voltage with a digital multimeter should be very easy. Check out below:
http://www.teamfc3s.org/info/articles/o2sensor.html
And somewhere on the net there is the complete voltage readings for the O2 sensor, but cannt find it now....I'm sure someone will tell us
Old May 16, 2002 | 03:52 AM
RETed's Avatar
Something is wrong...
You tried seeing if the ECU spits out any error codes?
At WOT it sounds normal, but at idle and light-load cruising, it's looks "broken".&nbsp I would've blamed a bad connection somewhere, but the WOT test shows SOME lights, so that can't be it.&nbsp The only other possibility is that you have a ground problem somewhere.&nbsp You might want to try and ground the O2 sensor body, but crimping on some kinda connector to a piece of wire and using a screw-type hose clamp to attach it to the O2 sensor body.&nbsp Run the other end to a known good ground and see if this helps anything...
-Ted
