Haltech could be simple but then again idk?
Old Oct 28, 2008 | 12:52 AM
boost_its_what_for_dinner's Avatar
RotoriousRx7
i have to enter a passwrod for the haltech e6x and if i dont i cant change or do much at all,so is the password made up or is it a serial number ? or what thx cause i cant find a serial number on the ecu.
Old Nov 16, 2008 | 02:26 PM
Nismo Convert86's Avatar
400WHP or bust
I had asked this question about 4-5 months ago, and got no answer, good to hear I am not the only one with this issue, It would be nice to be able to enable closed loop O2 and gain some Mileage out of the car. If you figured anything out let me know.
Old Nov 16, 2008 | 03:47 PM
Houstonderk's Avatar
My girl
I would assume that only sending to haltech would work, and probably would need some kind of proof of purchase for theft quality.
Old Nov 16, 2008 | 04:02 PM
C. Ludwig's Avatar
www.lms-efi.com
To get around the password you hit cancel when prompted to enter it. At that point you need to load the default map onto the ECU. Once you do that you can reload the map you had in the ECU and be ready to go. The problem arises when you do not have the map backed up to a file and have nothing to reload once you load the default map to get around the need for a password. Sending it to Haltech will not help.
Old Nov 23, 2008 | 09:43 AM
400WHP or bust
Yes that is exactly it, my dos laptop doesn't have a diskette drive, so I am SOL, I guess the best way is to get my tuner to send me an email with my map.
Thanks for the heads up Chris.
demetlaw
Oct 2, 2015 06:22 PM
WANKfactor
Sep 29, 2015 01:14 PM
rotor_veux
Sep 19, 2015 07:13 PM
