My Dyno Runs
Old Oct 27, 2008 | 09:00 AM
YellowSpeed17's Avatar
My Dyno Runs
Took my car to a Dyno Dynamics dyno yesterday. At 8psi it made 238.8hp/196tq and at 12 psi it made 273.4hp/230tq. Those are corrected numbers. Boost kept falling off after 5500rpms and at 12psi it was running a little lean. I was looking to make 300whp but I'm still happy with the results...I know it can make more power with a better tune,different exhaust, and different boost controller.
Mods:
Large streetported S4 JDM engine
Fidanza Aluminum Flywheel
Exedy Clutch
RTek7 1.8 ECU
Turbo XS HPDS boost controller
4 x GReddy 720cc injectors
BNR stage 1 turbo
Custom K&N filter with 3" TID
Custom FMIC
BDC throttle body
Racing Beat 3" downpipe
Stock catalytic converter
Apex'i N1 Duals
Attached Thumbnails My Dyno Runs-dyno-hp-afr-2.jpg   My Dyno Runs-dyno-hp-tq-2.jpg   My Dyno Runs-dyno-hp-psi-2.jpg
Old Oct 27, 2008 | 09:34 AM
Link to 12psi run: http://www.youtube.com/watch?v=YwP4MngQyjc
This run was in 4th gear from about 45mph-140mph.
Also, on the graphs the red is the 8psi run and the purple is the 12psi run.
And a FYI to anyone with a RE-Amemiya diffuser: you will have to take the diffuser off in order to strap the car down to the dyno.
Old Oct 27, 2008 | 10:54 AM
BDC's Avatar
BDC
BDC Motorsports
Those are pretty good numbers on that turbo!
B
Old Oct 27, 2008 | 12:42 PM
B
Thanks. BTW I got my BDC throttle body from someone else on the forum but I love it! The porting, polishing, and knife edging on it is amazing!
Old Oct 27, 2008 | 12:57 PM
junito1's Avatar
F**K THE SYSTEM!!
NICE!!!!
Im looking to make a little more than those numbers but with stock ports and a BNR4.
Looking more possible. thanx
Old Oct 27, 2008 | 03:27 PM
MaczPayne's Avatar
Mac Attack
That's a sweet sounding car you have there. I wished I still had the N1 duals.
Old Oct 27, 2008 | 06:16 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
ditch that stock cat and you should be at 300whp, but you will need more injector though
Old Oct 27, 2008 | 07:03 PM
junito1's Avatar
F**K THE SYSTEM!!
yeah i would ditch the cat too. If you can get away with it. If not move to florida, no emissions here=D
Old Oct 27, 2008 | 07:40 PM
I know the stock cat is limiting the power but I had a couple problems when I was running a 3" test pipe. First I kept getting loud exhaust tickets,cops are real dicks around here, and they didn't like 2-3 foot flames=) And second, running just off the wastegate, the boost would spike to 14-15psi. When I run the stock cat, it runs at 8psi and falls off to 5psi. I'm going to be ditching my manual boost controller and probably get a GReddy Profec. I also plan to get the RTek 2.1 and maybe 1000cc injectors. I'm also contemplating getting rid of the Apex'i duals and going with the GT-Spec but I love the look and sound of the duals.
Old Nov 25, 2008 | 10:21 PM
jmrice's Avatar
Those are really good numbers for the upgrades you have! With 270?rwhp, you can really hurt some feelings on the street, and make some good respectable passes at the track...........Way to Go!! Keep us posted on any additional numbers.
Old Dec 9, 2008 | 09:43 PM
pyscho7's Avatar
Let me Axe you a question
that is one big wing on that thing. but nice car. hope you get it straightened out, you got a very similar set up to what im going to be running here shortly, i went ahead and bought 1000cc rc engineerings for secondaries though, and all my emissions are removed, and i believe my turbo is a little bigger.
Old Dec 9, 2008 | 09:56 PM
blimp's Avatar
nice car! Is that the re wing too? Got any pics with the diffuser on?
Ya dude that sux that you gotta use your stock cat, ya change that turbo and put a resonated test pipe in there!!!!!
Old Dec 10, 2008 | 01:26 AM
KhanArtisT's Avatar
Former FC enthusiast
Those are great numbers considering you don't even have a fuel controller for the 720ccx4s. The RTEK 1.Xs are awesome.
Old Dec 19, 2008 | 12:30 PM
The wing is from Garage BB. It took about 2 months to get from RHDJapan. I don't have any pics with the diffuser on yet...probably won't have any good ones until the spring.
In the spring I'm planning on either getting a BNR stage 3 or 4, bigger injectors, and RTek 2.1 or buying a S14 and putting in a RB25....decisions...
Old Dec 19, 2008 | 06:08 PM
drifter_sr's Avatar
this is not badd man.. pretty good.. great numbers man
Old Dec 21, 2008 | 06:29 PM
misterstyx69's Avatar
Retired Moderator, RIP
Thank you!
My Future setup is along those same specs,So Now I don't have to "estimate" my HP potential..
Those are not Numbers to be ashamed of..very Nice..Congrats!
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
dkwasherexd
May 27, 2017 04:51 AM
Turblown
Aug 14, 2015 04:48 PM
