S4 and S5 tranny mounts
Old Oct 22, 2008 | 07:36 PM
fc1990's Avatar
alright i just swapped in a s4 trany into my s5 fc. i noticed that my tranny mount was different and the brace that holds the trany up is different too. now my question is are the braces and the mounts different . cause right now im lost on what to do. btw the s4 tranny i have has 2 bolts that hold it to the tranny is that right...
Old Oct 22, 2008 | 08:18 PM
Black91n/a's Avatar
You need an S4 crossmember.
Old Oct 22, 2008 | 08:32 PM
fc1990's Avatar
so the mounts are different then . alright well if thats it than i can probly find that somewhere . im just making sure the mounts are different .
Old Oct 23, 2008 | 12:55 AM
FC3Sdrift's Avatar
Displacement Replacement
the actual mounts are the same the tranny cradle and crossmember are different, you could get them both new from mazda for 80 or so
Old Oct 23, 2008 | 05:46 AM
Turbonut's Avatar
Make certain the 2 trans mounts are good and not collapsed. If not, it will knock out the bushing in the crossmember if the mounts have settled.
Old Oct 23, 2008 | 07:58 AM
fc1990's Avatar
no the crossmember i need is different . my car is a s5 with a s4 trany. now i was looking at my broken s5 trany and the mounts go on the sides of the trany and it has 4 bolts to hold the mount to the trany not the 2 my s4 trany dose. so dose this mean all i need is a s4 crossmember or dose it mean i need more.
Old Oct 23, 2008 | 08:53 AM
Turbonut's Avatar
Crossmember from the S4, either Turbo or N/A as they are different. When you use the S4 crossmember it will bolt correctly to the frame and existing S4 trans mounts.
Old Oct 23, 2008 | 10:26 PM
fc1990's Avatar
what is the difference between the N/A and the Turbo S4 crossmember.
mulcryant
Sep 9, 2015 05:24 PM
SakeBomb Garage
SakeBomb Garage
Sep 4, 2015 05:20 PM
SakeBomb Garage
Vendor Classifieds
Sep 4, 2015 05:19 PM
