i have a question i need a quick answer to:)
Old Oct 20, 2008 | 06:50 PM
88 rx7 drh's Avatar
Question i have a question i need a quick answer to:)
im pullin my motor and need to know if i have to pull the intake to unplug the one under the intake? i have a 88 convertable 13b non turbo
Old Oct 20, 2008 | 07:07 PM
rrw's Avatar
rrw
Rapidly Running Wild
intake as in intake manifold
and the one under has how many wires?
Old Oct 20, 2008 | 07:21 PM
Osirus9's Avatar
Jackstand Drifter
to unplug the what under your intake?
Old Oct 20, 2008 | 07:31 PM
88 rx7 drh's Avatar
yes i dont see any way to get under the intake manifold so i can unplug it
Old Oct 20, 2008 | 07:34 PM
Osirus9's Avatar
Jackstand Drifter
what the hell are you unplugging?
I assume you mean you want to get all the wires that go under the UIM off so that you can pull your motor. If that is infact what you are trying to say, then yes, the UIM will have to be removed, and then replaced if you plan on using the stock hanging points for hooking up an engine hoist.
Old Oct 20, 2008 | 07:49 PM
88 rx7 drh's Avatar
ok thanks.
Old Oct 20, 2008 | 07:57 PM
dawicka2's Avatar
well rested,buffet o food
good luck with the job. It is not too bad.
john ny
Old Oct 20, 2008 | 07:59 PM
rrw's Avatar
rrw
its easier just to unplug the harness at the ecu and pull it through the firewall and then take the harness off while the motors out
Old Oct 20, 2008 | 08:19 PM
need RX7's Avatar
Listen to King Diamond.
+1
Old Oct 20, 2008 | 08:24 PM
88 rx7 drh's Avatar
GREAT IDEA thanks a bunch!!!!
Old Oct 20, 2008 | 11:59 PM
2slow4stock's Avatar
The waiting game......
+3 for pulling harness through firewall.
Old Oct 21, 2008 | 05:06 PM
88 rx7 drh's Avatar
how can i get the the ecu plug?
Old Oct 21, 2008 | 05:14 PM
Osirus9's Avatar
Jackstand Drifter
i always do it the way i mentioned previously... it saves you from having to reach under your dash and try to get to the ecu plug while laying on your back with a flashlight in your mouth. But whatever floats your boat.
Old Oct 21, 2008 | 05:27 PM
need RX7's Avatar
-Pull up passenger side carpeting (you will need to remove plastic skid plate thing)
-You will see a metal kick plate held on by a few nuts, remove it, ECU is under there
-Follow wiring harness from where it enters the firewall and unplug it (should be 2 or 3 plugs, depending on series.. I think) There are also a few wires held down with nuts around the general vicinity
-Push grommet through, along with the harness itself while someone else pulls it through
-Coil harness on top of motor and pull the motor with everything still connected.
It's much easier to unplug 2 plugs and then pull everything else outside of the car, rather than trying to snake your hands all over the engine bay trying to disconnect everything. Not to mention trying to reconnect every single plug in the engine bay when it goes back in.
Old Oct 21, 2008 | 06:13 PM
mikevoch89146's Avatar
osirus9 you sig cracks me up
Old Oct 22, 2008 | 10:34 AM
dawicka2's Avatar
How did the engine removal work out for you?
I always pull the engine the way osiris does as well.
maybe next time i will try it at the ecu (hopefully not for a while though) .
John ny
Old Oct 22, 2008 | 05:02 PM
88 rx7 drh's Avatar
i havent gotten to it yet. due to the fact that im 15 and have school but i think ill head out now and ill let you know when its out!
Old Oct 22, 2008 | 05:48 PM
88 rx7 drh's Avatar
i cant get the pugs un clipped on the side. any tricks or ideas?
Old Oct 22, 2008 | 06:10 PM
88 rx7 drh's Avatar
scratch that i got it through the fire wall!
Old Oct 26, 2008 | 03:07 PM
88 rx7 drh's Avatar
the motor and tranny are out.
wickedrx2
The Bad & Fugly Members
Jun 10, 2021 06:28 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
